change brake pads in the back?
Old 12-05-2003, 10:54 AM
sting94112's Avatar
Default change brake pads in the back?
i know how to change brake pads in the front, and the back should be the same, but do u have to bleed the brakes for the back?
Old 12-05-2003, 11:05 AM
Op IVY Si's Avatar
If you open up the lines then yes you should bleed the system. You need a special tool to push the piston back in on the rear brakes. Just a heads up if you did not already know.
Old 12-05-2003, 11:13 AM
clm
clm's Avatar
Default Re: (Op IVY Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Op IVY Si &raquo;</TD></TR><TR><TD CLASS="quote">You need a special tool to push the piston back in on the rear brakes. </TD></TR></TABLE>
Not really. On my del Sol rear disc brakes the piston was like a phillips screw. I just grabed a thick straightedge and turned it back in. You should lube the seals with some sort of oil, though.
Do you have rear disc brakes, though? Or drums? Discs are mostly the same as the front; not hard to figure out. Drums I have no idea.
Old 12-05-2003, 11:17 AM
=GAME='s Avatar
Default Re: (clm)
for the rear disc calipers, all you would need is a needle nose pliers and turn it clockwise to get the piston back in.
Old 12-05-2003, 11:43 AM
sting94112's Avatar
Default Re: (O.G triple O.G)
for the front i used a C clamp. can i use a C clamp in the back too ?
Old 12-05-2003, 11:45 AM
=GAME='s Avatar
Default Re: (sting94112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sting94112 &raquo;</TD></TR><TR><TD CLASS="quote">for the front i used a C clamp. can i use a C clamp in the back too ?</TD></TR></TABLE>
back no. all u need is a needle nose plier, open it up a bit and turn the piston with it going clockwise.
Old 12-05-2003, 02:45 PM
boosted eg's Avatar
or you can use a prybar too thats what i used but all methods work if u dont have the proper tool forgot what its called though its a cube though.
LSVTEC 91 Civic
Honda Fit
37
11-15-2007 05:52 AM
jmk64
11-05-2006 04:50 AM
EG2Driver
06-18-2006 12:45 PM
GSRnold
08-22-2004 04:29 PM
sting94112
Acura TL, RL & ZDX
11-05-2003 10:01 PM
Quick Reply: change brake pads in the back?
