ZC CRAPPY OR GOOD ENGINE?
Old Sep 9, 2004 | 01:32 PM
NismoMugen's Avatar
Default ZC CRAPPY OR GOOD ENGINE?
yes my b16 died....my brother took it without telling me and blew tha engine....
so now im stuck with gettin a zc dohc....so i was wondering is this engine crap? i have a turbo in my shed from a mitsubishi eclipse cuz i heard zc takes tha turbo better or something like that.....nneeewwaayyss the place im gettin the engine from said that im gettin a brand new tranny for it( my dad talked to tha guy bout it which he forgot what they said..he has altimers ), something that specificly works good with tha zc engine.
Old Sep 9, 2004 | 01:34 PM
daidilus's Avatar
Default Re: ZC CRAPPY OR GOOD ENGINE? (NismoMugen)
WTF!!!???? if he blew the engine...he should buy you another one...if any part of it salvagable? can you rebuild....you will feel let down going from B16A to ZC
Old Sep 9, 2004 | 01:37 PM
NismoMugen's Avatar
Default Re: ZC CRAPPY OR GOOD ENGINE? (daidilus)
im broke but yea i kicked his ***..literally
Old Sep 9, 2004 | 01:46 PM
wtsexton's Avatar
Just get a b16a long block.
Old Sep 9, 2004 | 01:54 PM
Reelizmpro's Avatar
Default Re: (wtsexton)
Won't you have to undo the B series conversion to go back to a "D" series? Make him pay for another B16A...perhaps the 2nd gen 170HP version =]. **** it....ITR engine.
Old Sep 9, 2004 | 02:41 PM
mar778c's Avatar
Community Builder
Community Influencer
No, a zc is not a crappy engine. But it will be slower than a b16. In terms of putting it in, the vtec wiring will have to go but it's not very hard.
Old Sep 9, 2004 | 02:44 PM
ihateslowhondas's Avatar
zc is poo poo rebuild the b16 or buy a short block like b18 or b20
Old Sep 9, 2004 | 05:27 PM
StorminMatt's Avatar
A ZC is a definite step down from a B16A. I personally would just try to find a B16A longblock. This is, after all, all you need. And you could probably find one for little more than a ZC. Maybe even less if it is a bare longblock (no manifolds, distributer, etc.). Also keep in mind that if you go ZC, you will need all the D-series stuff again to make it work. And if you have long since sold your stock transmission, axles, etc., then you will have to buy all this stuff at considerable expense. If this is the case, it is DEFINITELY not cost effective to go ZC.
Old Sep 10, 2004 | 04:23 AM
daidilus's Avatar
Default Re: ZC CRAPPY OR GOOD ENGINE? (StorminMatt)
DOOOOODDD DOOONNNNTTT DOOO ITTTTTT
B16A LONG BLOCK
599.00 PLUS SHIPPING
http://www.hmotorsonline.com/s...30021
JUST REPLACE YOUR BLOWN ****..I AM SURE SOMETHING IS SALVAGABLE...SELLL WHAT YOU CAN
ZC 525.00 plus shipping
and HMO is the shiznittle STEve is aweSOME
Old Sep 10, 2004 | 04:33 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NismoMugen &raquo;</TD></TR><TR><TD CLASS="quote">im broke </TD></TR></TABLE>
so, why are YOU paying for it make HIM pay for it .
get a b18b bottom end, cheap and better
Old Sep 10, 2004 | 05:52 AM
drussell4801's Avatar
you can probably get your parenst to feel somewhat responsible for your brother's actions.
that is, if you play it right.
Old Sep 10, 2004 | 05:58 AM
Charlie Moua's Avatar
well since your already packing B series why don't you just keep your mounts, axles, ect and get a B20.
man a b20 with skunk2 IM, h-i-e with b16 tranny would rip apart any stock b16 anyday.
Old Sep 10, 2004 | 08:59 AM
hatchinprogress's Avatar
Default Re: ZC CRAPPY OR GOOD ENGINE? (Charlie Moua)
well its not a b16 but the zc is still strong and it will do good with a turbo
Old Sep 10, 2004 | 09:04 AM
rsbad454's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">well since your already packing B series why don't you just keep your mounts, axles, ect and get a B20.
sure it would......
Old Sep 10, 2004 | 09:07 AM
EP3_05's Avatar
Default Re: ZC CRAPPY OR GOOD ENGINE? (rsbad454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">
sure it would...... </TD></TR></TABLE>
Actually the b20 w/ bolt ons is a pretty powerful setup. My buddy has one in his crx with i/h/e and he and I run neck and neck in the quarter except that I pull away a bit on the top end. Remember the b16a doesn't have alot down low.
Old Sep 10, 2004 | 09:09 AM
DocSean's Avatar
I assume you mean a b20 WITH a b16 head???
Old Sep 10, 2004 | 09:11 AM
DocSean's Avatar
Default Re: ZC CRAPPY OR GOOD ENGINE? (91civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">
Actually the b20 w/ bolt ons is a pretty powerful setup. My buddy has one in his crx with i/h/e and he and I run neck and neck in the quarter except that I pull away a bit on the top end. Remember the b16a doesn't have alot down low.</TD></TR></TABLE>
Depends a lot on what B20 and why trim level your buddies CRX is also. B20z in an HF w/ bolt on's would probably definitely hold its own against a 4door civic with stock b16a.
Old Sep 10, 2004 | 09:18 AM
The ZC's Avatar
Default Re: ZC CRAPPY OR GOOD ENGINE? (spankjelly)
It would be cheaper for you to stay B. You already got the mounts and the tranny, if you go back to D you will have to change that stuff out.
The ZC is not a step down its just a different motor. You won't have to rev as high as the b16 but you wont have as much power.
CRV-Vtec
Old Sep 10, 2004 | 09:22 AM
skittyscott's Avatar
sell whats left of the b series stuff, mounts, axels, linkage, head... whatever and buy the zc. then, with the leftover money turbo it!
Old Sep 10, 2004 | 10:18 AM
95stangkillah's Avatar
just curious how he blew your engine? overrevved it like 10k rpm? blew a hole in the block? you might be able to get away with a small rebuild. blown head? get another one for a few hundred. same for the block. what's holding you from rebuilding?
Old Sep 10, 2004 | 10:55 AM
Ass$nyper's Avatar
Pirate General...YARRRR
well that sucks big time but as far as ZC motors there good stay B though caues your already there what happened to the motor?
Old Sep 13, 2004 | 11:13 PM
CRX_1.8T's Avatar
FRIENDS DON'T LET FRIENDS SWAP ZC's.
Old Sep 13, 2004 | 11:22 PM
91 HONDAsaurus rex's Avatar
Default Re: ZC CRAPPY OR GOOD ENGINE? (CRX_1.8T)
I would say stay b series. If you do go ZC you think i can buy your iac valve.
Old Sep 14, 2004 | 03:23 AM
Home Skillet's Avatar
Default Re: ZC CRAPPY OR GOOD ENGINE? (mrspeaker)
Get the B16A longblock from the previous link and turbo it!!!
Old Sep 14, 2004 | 04:43 AM
Default Re: ZC CRAPPY OR GOOD ENGINE? (Home Skillet)
Speaking of turbo, a B16A has MUCH greater internal fortitude than a ZC. It can take more boost on a stock bottom end (or a built bottom end, for that matter) before it blows up. And don't tell me about compression. Because the difference is not THAT great.
And regardless of what anyone says, a ZC is a step down from a B16A. Remember that a ZC is basically just an LS minus 200cc. And I even consider an LS to be a step down from a B16A.
As far as B16A vs non-VEC B20, they actually are pretty even in the quarter mile. Even on the dyno, the B20 almost puts out as much power. But the real difference is on the street, where the torque of the B20 rules.
