main bering caps
Old Dec 7, 2001 | 02:04 PM
One8Hatch's Avatar
New User
Default main bering caps
how do you remove the main bering caps after you removed the bolts? there awfuly stubburn. thanks
Old Dec 7, 2001 | 04:35 PM
Jared's Avatar
Default Re: main bering caps (One8Hatch)
Try wobbling them slightly.
Old Dec 7, 2001 | 06:29 PM
Mike K's Avatar
Default Re: main bering caps (Jared)
put the bolts back in the bearing caps.. but not deep enough to get to the block threads... push one bolt away from you and pull one toward you so they are stiff..
rock back and forth, using the bolts as "pry bars" so to speak.
then throw out the bolts.. because you should be replacing them anyway.
if that doesnt work, get some channel locks and be careful.
killerpenguin21
14
Jul 13, 2006 04:37 PM
Aeka GSR
Apr 23, 2004 05:38 PM
SleepyHF
Apr 19, 2004 12:03 AM
Bnjmn
Mar 20, 2002 06:31 AM
