what are some Realistic numbers for my set up. PLZ help!
Old Sep 9, 2004 | 01:10 PM
CivicSiRracer69's Avatar
Default what are some Realistic numbers for my set up. PLZ help!
Head
95 D16z6
Port and polish
3 angle valve job
Port matched
bowls polished
zex 59300 cam
AEM cam gear
Crower Ti retainers
Zex Valve springs
Crower 1mm over sized Valves, slick coated
Air / fuel
Venom SheetMetal Intake manifold
Venom Y8 Fuel rail
RC 550's
AEM FPR
Hondata IM gasket
69mm TB
MSD SCI
MSD Cap
MSD Coil
OBX 10.3 6 core wires
Block
94 D16z6
Eagle H beams
Wiseco 9:1 pistons With Wrist pins and rings .5 mm over sized
KMS Block guard
Honed, bored, decked
All ARP hard ware
Tranny
00 D16y8
Vti LSD
Cryo'd Gears and Input shaft
ACT 6 puck
ACT Extreme PP
ACT street light fly wheel
Turbo
Braced and ceramic coated equal length Mani
Tial 35mm WG with Blue spring
T3T4 60 trim Turbo with Stage 3 compressor wheel
5 bolt 2.5" Down pipe Cermaic coated with Flex
2.5" Charge piping All ceramice coated
3" charge piping from Compressor to filter located in Cold air spot
Turbo X's RLF
Blitz Timer
Turbo X's Boost controler
All silcon couplers W/ T bolts
3 bar map sensor
Hondata s200b p28
6" Johnny race car FMIC
Old Sep 9, 2004 | 02:05 PM
CalGSR99's Avatar
Default Re: what are some Realistic numbers for my set up. PLZ help! (CivicSiRracer69)
Time to whip out my "Horsepower For the Anonymous Person Calculator" Again.
<--- Puts in secret code and boots up Mainframe
Now i need to input your options.
<-- Click, Click, Click, Click, Click
***** computing ***
**** computing **
Ok, my analysis tells me with 100% acuracy that you will without a doubt have 372.589 whp @ 7500 rpm with 262.35789 torque.
Would you like me to give you the winning lotto numbers too while i got this baby booted up?
Old Sep 9, 2004 | 02:36 PM
whackassfawker's Avatar
Default Re: what are some Realistic numbers for my set up. PLZ help! (CalGSR99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CalGSR99 &raquo;</TD></TR><TR><TD CLASS="quote">Time to whip out my "Horsepower For the Anonymous Person Calculator" Again.
&lt;--- Puts in secret code and boots up Mainframe
&lt;-- Click, Click, Click, Click, Click
***** computing ***
**** computing **
Would you like me to give you the winning lotto numbers too while i got this baby booted up?</TD></TR></TABLE>
Are you being sarcastic? It's really hard to tell on the net!!!
Move over Seinfeld.
Old Sep 9, 2004 | 02:47 PM
98JDM_Type_R's Avatar
amazing, that is what I came up with. the only diffence was torque. I came up w/ 262.35788
Old Sep 9, 2004 | 02:57 PM
CalGSR99's Avatar
Default Re: what are some Realistic numbers for my set up. PLZ help! (98JDM_Type_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98JDM_Type_R &raquo;</TD></TR><TR><TD CLASS="quote">amazing, that is what I came up with. the only diffence was torque. I came up w/ 262.35788 </TD></TR></TABLE>
Dang, i think i need to update my software then! And no, im not being sarcastic. These machines are used in "fortune cookies" to tell your fortune, why do you think they are so accurate?
Old Sep 16, 2004 | 09:57 PM
... wow for the tards. Just wanted in the neighborhood, leave it to the newbs
XES
Oct 18, 2005 11:22 AM
CivicSiRracer69
Nov 21, 2004 08:35 PM
CivicSiRracer69
Sep 7, 2004 06:00 PM
CivicSiRracer69
Jul 13, 2004 06:36 PM
cnydelSolHybrid
Jun 25, 2003 02:53 PM
