vtec profile specs
Old Sep 9, 2004 | 01:02 PM
MidShipCivic's Avatar
Default vtec profile specs
Crower, Comp Cam, ETC there cam specs are like Pri-Sec-Mid
If there are 3 lift and Durations how come everyone says there are 2 profiles on VTEC cams, when there are 3 lobes that are different?
Wouldn't it be really be 6 cams in one engine instead of 4.
http://www.compcams.com/Techni...1.asp
Old Sep 9, 2004 | 01:18 PM
Default Re: vtec profile specs (MidShipCivic)
bump
Old Sep 9, 2004 | 01:38 PM
mmuller's Avatar
Mad Scientist
beacause there is 2 profiles, but 3 different lobes.
outer 2 and then the middle one
Old Sep 9, 2004 | 02:22 PM
Default Re: vtec profile specs (mmuller)
Alright that clear up my understanding, thanks.
So it would be 6 cams in one engine, as I was saying above.
Old Sep 9, 2004 | 04:58 PM
bump
Old Sep 10, 2004 | 07:16 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">Alright that clear up my understanding, thanks.
So it would be 6 cams in one engine, as I was saying above.</TD></TR></TABLE>
no, how do you figure.
http://www.howstuffworks.com
do a search for vtec
Old Sep 10, 2004 | 04:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
do a search for vtec</TD></TR></TABLE>
I'm not stupid, each lobe has different specifcations meaning the 2 outer lobes arent the same.
That would be 6 cams in one engine.
Old Sep 10, 2004 | 06:16 PM
Heylookits shawn's Avatar
six cams in one engine? hrmm.... thats a lot of vTAKKKK
no matter how different the lobes are there are still only two cams
Old Sep 10, 2004 | 06:37 PM
johnb18a1doe's Avatar
Maybe your "mid ship civic" has six cams...
Old Sep 11, 2004 | 09:39 AM
Default Re: vtec profile specs (Heylookits shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">six cams in one engine? hrmm.... thats a lot of vTAKKKK
no matter how different the lobes are there are still only two cams</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Maybe your "mid ship civic" has six cams...</TD></TR></TABLE>
I did'nt know this is where retards try and take a whack at tech questions.
No not six cams EQUIVALENT TO 6 camhshafts since all 3 lobs have different specifications, if you not gonna anwser my question why bother making stupid *** comments.
Old Sep 11, 2004 | 10:17 AM
mmuller's Avatar
Mad Scientist
the primary and secondary lobes are different but work at the same time in the ''low rpm cam'', they are different to promote swirling and a more even burn in the combustion chamber.
the mid lobe, well is the high rpm cam lobe.
Old Sep 12, 2004 | 04:46 PM
TeamCracka's Avatar
Six different cam profiles - two cams - simple.
Old Sep 12, 2004 | 05:30 PM
beaterdriver's Avatar
but when you are in vtec, the out lobes arent doing anything, so they are disregarded, on the middle lobe is doing the work. there is still only 4 valves per cyclinder
D17alltheway
Honda Civic (2001 - 2005)
19
Jun 9, 2008 03:05 PM
CRX VT-DOO
12
Oct 28, 2006 12:35 PM
street dreams
14
Jun 6, 2006 03:52 AM
bugster
Jan 28, 2005 10:18 PM
GreyRS
Dec 27, 2001 01:48 AM
