Turbo F22
Old Sep 9, 2004 | 12:34 PM
1994integradc2's Avatar
Default Turbo F22
Hey guys,
Heres the deal... i picked up a great condition 90 accord ex 5speed, after seeing my friends h22a accord perform i wanted to do something similar.
I want to do something different, i think i want to stick with the f22 that is in the car currently. Has anyone Turbo charged the f22? if so can you give me the list of parts and the best turbo suited for that motor. Now i have ridden in a few turbo hondas and i don't want mine to sound like theirs.. i want it to be smooth and i want to hear turbo not the wastegate. it probably sounds dumb but i am very picky.. i love this body accord and i dont want an h22a (4 exist in accords) in a 10 mile radius. Thanks
Old Sep 9, 2004 | 01:21 PM
asmo's Avatar
Default Re: Turbo F22 (Accord90Ex)
I didnt think the f22 came out until 94 ?? i could easily be wrong tho.
Old Sep 9, 2004 | 01:55 PM
TxTuner
Guest
Posts: n/a
Default Re: Turbo F22 (asmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord90Ex &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone Turbo charged the f22? </TD></TR></TABLE>
Have astronauts landed on the moon? Try the search button
Old Sep 9, 2004 | 07:52 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
It's rare. I don't believe they make an actual kit for the f22 ( maybe that's just the prelude). You have to piece it together. Also, the low compression is a plus, but since you are starting off with such a low hp, you won't see very large gains. It is unique though
Old Sep 9, 2004 | 09:21 PM
a94si's Avatar
Default Re: Turbo F22 (92prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92prelude &raquo;</TD></TR><TR><TD CLASS="quote">
It's rare. I don't believe they make an actual kit for the f22 ( maybe that's just the prelude). You have to piece it together. Also, the low compression is a plus, but since you are starting off with such a low hp, you won't see very large gains. It is unique though </TD></TR></TABLE>
There are plenty of turbo kits for the f22. Drag, fmax, a few others I can't think of right now.
I think it was accordfreak that had a turbo on his f22 that was putting out around 260hp/280tq. I'd call that a pretty good gain from a motor with 145hp stock.
Old Sep 9, 2004 | 10:08 PM
madd's Avatar
Default Re: Turbo F22 (a94si)
you should have an f22a, in which case, you should be able to use the "junkyard" approach. you can get your turbo manifold and other goodies from the good ole DSM 1g (believe this is the right gen) for really cheap. this would be a perfect starter set, in my opinion, but only if you are in to learn about how everything works. piecing it together will teach a lot of things...especially if you're doing the work yourself. if you simple want the powa go with one of the kits...and good luck
Old Sep 10, 2004 | 03:40 AM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a94si &raquo;</TD></TR><TR><TD CLASS="quote">
Show me ONE for the f22a
Old Sep 10, 2004 | 06:24 AM
H2290's Avatar
Default Re: Turbo F22 (VRDrvr)
I'm not trying to argue but wouldn't most of these be for the F22A? They state F22 but also say 90-93 Accord. And since the F22A is what came in those cars wouldn't it mean it is for that engine?
=====&gt;
http://www.turbo-kits.com/accord_turbo_kits.html
Old Sep 10, 2004 | 08:43 AM
TOAB's Avatar
yes they make ones for 4th gens (junkyard dsm approach is cheaper though) and ones for 5gens. you cant use a 4th gen mani on a 5th gen as the ports are different
Old Sep 10, 2004 | 08:47 AM
JayFI's Avatar
For some odd reason, when I was looking for infos for turboing my F22b2, I find no info/query in here nor other forums. Now that I got my stuff together, ppl started popping out of the woodworks and asking similar stuff... I think I started a trend.
For complete kits:
http://www.dragturbokits.com/index.html
For the F22 turbo manifold use in a custom setup with T3 flange. Post this b/c took me the longest to find, and hardest to find. I even found a place that sells the collector to connect the T3 flange to a T25 turbo instead. Let me know if you want that info as well. Charges $80 for that collector.
http://www.importparts.com/sho...=2208
And I've posted some of this in other threads. So yes, "search" button is your best friend, and so is google.
Old Sep 10, 2004 | 12:38 PM
TxTuner
Guest
Posts: n/a
Default Re: Turbo F22 (Jed Atreides)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jed Atreides &raquo;</TD></TR><TR><TD CLASS="quote">Now that I got my stuff together, ppl started popping out of the woodworks and asking similar stuff... I think I started a trend.</TD></TR></TABLE>
Yes, you single handedly started the trend of wanting to boost the f22 Congratulations
Old Sep 10, 2004 | 01:29 PM
The_Todd's Avatar
Farts in the shower
Default Re: Turbo F22 (H2290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not trying to argue...</TD></TR></TABLE>
Me either
Ok so there is 1 kit available that costs 2800 bucks . The biggest reason is for manifold placement
0 0 0 0 -----f22a
0 00 0 -----f22b
But I have gotten my dsm setup for 600 bucks:
t25
manifold
injectors
safc
IC
BOV
And IMO its the same one as the revhard kit .
Old Sep 10, 2004 | 03:22 PM
Community Builder
:Contemplates going turbo for the lude:
I wish it showed prices on dragturbokits, but its under construction.
Old Sep 10, 2004 | 11:00 PM
twkdCD595's Avatar
Default Re: Turbo F22 (TxTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you single handedly started the trend of wanting to boost the f22 Congratulations </TD></TR></TABLE>
lol... turbo on an f22... wow what an idea.
Old Sep 10, 2004 | 11:53 PM
JayFI's Avatar
I should've posted only facts. Any nonchalant comment invites the diss-a-licious ethugs to beat it to death.
$600 for all those dsm setup parts, sweet deal.
Old Sep 11, 2004 | 09:13 AM
twkdCD595's Avatar
just teasing you a bit... dont take it personal... its ht tradition.
ethug... I like that.
Old Sep 11, 2004 | 11:15 AM
TxTuner
Guest
Posts: n/a
Default Re: Turbo F22 (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jed Atreides &raquo;</TD></TR><TR><TD CLASS="quote">Any nonchalant comment invites the diss-a-licious ethugs to beat it to death.</TD></TR></TABLE>
LOL, that's going in my sig. Naw, like he said, we're just ******* with you
Old Sep 14, 2004 | 09:29 AM
rival12's Avatar
Turbonetics makes a kit 145hp to 210hp 8psi
Old Sep 14, 2004 | 11:15 AM
jakeiscool's Avatar
Banned
I'd call that a pretty good gain from a motor with 145hp stock. </TD></TR></TABLE>
Well b1 headed f22s make 145 but not b2s
Old Sep 15, 2004 | 06:42 PM
JayFI's Avatar
Default Re: Turbo F22 (JakeIsCool)
So how much does b2 make?
Old Sep 15, 2004 | 07:58 PM
TOAB's Avatar
Default Re: Turbo F22 (rival12)
people should probably keep in mind that those numbers are probably only after being properly tuned.
game_accord
Oct 6, 2011 09:58 PM
kewlmonkey
Sep 20, 2006 11:04 AM
abeaujuin
May 26, 2003 07:59 AM
tsjag17
Apr 11, 2002 11:41 PM
