junkyard turbo people i need your help
Old Sep 9, 2004 | 11:40 AM
cheetah64's Avatar
Default junkyard turbo people i need your help
After doing some research i think im going to keep my f22 in my 95 accord for now and just turbo it. However, i think im going to go the junkyard turbo way but i have a few questions. First of all, when im looking for a turbo what kind of things should i look for physically? I mean how can i tell if its ready for a rebuild? Also what other parts should i look for there because obviously finding a manifold will be nearly impossible at a junkyard? I was thinking i could find a turbo(hopefully with a wastegate), intercooler (from like an old saab or volvo) and bov (if im lucky). Im basically lookin for some help from people that have successfully done a junkyard turbo. Thanks
Old Sep 10, 2004 | 01:24 PM
TxTuner
Guest
Posts: n/a
Default Re: junkyard turbo people i need your help (cheetah64)
PM VRdrvr. He's a couple days away from finishing his junkyard turbo. There will be a write up along with dyno sheets soon after he finishes.
Old Sep 10, 2004 | 01:27 PM
.bagged's Avatar
Default Re: junkyard turbo people i need your help (TxTuner)
Find a early 90's talon and gank the **** out of it.
Old Sep 10, 2004 | 02:53 PM
Schmitey's Avatar
Default Re: junkyard turbo people i need your help (bagged93accord)
second that, I had a 90 Eclipse
that 2 litre is the bomb diggity and very easy to work on...however Mitsu is gay in the fact that they force you to buy specialized tools (unless your dad is a clever engineer)
I've heard that you can also steal the manifold and everything from the 90-94's and bolt it up to the f22s, but don't quote me on that. Also man save yourself some hastle and look on ebay. You can find old Eclipse/Talon/Laser turbo setups VERY cheap.
Old Sep 10, 2004 | 04:38 PM
TxTuner
Guest
Posts: n/a
Default Re: junkyard turbo people i need your help (Schmitey)
Yes the manifold's will bolt up but you need to tap new holes for the actual bolts
Old Sep 10, 2004 | 08:07 PM
cheetah64's Avatar
just tap new holes on the manifold? hmm...do you happen to know the ballpark price range of a used talon manifold because that seems like it could be an even cheaper way to turbo...but there must be some reason other people dont use it, reliability maybe?
Old Sep 10, 2004 | 08:14 PM
TxTuner
Guest
Posts: n/a
This is the exact manifold, if I'm not mistaken, that VRdrvr is using. PM him with any questions you might have.
Old Sep 10, 2004 | 08:18 PM
cheetah64's Avatar
k will do thanks!
Old Sep 10, 2004 | 08:25 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheetah64 &raquo;</TD></TR><TR><TD CLASS="quote">k will do thanks!</TD></TR></TABLE>
5th gen is f22b, the setup is going to be different.
0 0 0 0 -----f22a
0 00 0 -----f22b
Old Sep 10, 2004 | 08:33 PM
cheetah64's Avatar
hmm so is there any other car that has a manifold that would work? also i was thinking, would it be easier to just supercharge it from like an old thunderbird?
Old Sep 10, 2004 | 08:35 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheetah64 &raquo;</TD></TR><TR><TD CLASS="quote">hmm so is there any other car that has a manifold that would work? also i was thinking, would it be easier to just supercharge it from like an old thunderbird?
Nope, you can gank the turbo setup off an early 90's talon or eclipse. but as far as the mani goes you will have to do a custom setup, since you have an F22b
TxTuner
Guest
Posts: n/a
Bagged, is VR's the 22a or 22b? Can't remember but let me know so I can stop sending peeps his way. Oops
Old Sep 10, 2004 | 08:36 PM
.bagged's Avatar
lol.. his is f22a
Old Sep 10, 2004 | 08:37 PM
cheetah64's Avatar
its 22a
Old Sep 10, 2004 | 08:38 PM
cheetah64's Avatar
ok thanks anyway guys
TxTuner
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">lol.. his is f22a</TD></TR></TABLE> alright, thanks for the correction
Old Sep 10, 2004 | 08:39 PM
.bagged's Avatar
No problem guys.
Old Sep 11, 2004 | 11:01 AM
Schmitey's Avatar
the talon manifolds (turbo that is) are hella cheap used...if i remember right around $25-50
the whole setup? can't remember
stknfghtr1
Aug 3, 2011 06:21 PM
WanaBeFaster
May 5, 2011 06:30 AM
t_boneshacone
Aug 21, 2008 03:39 PM
djxtc65
Mar 29, 2005 05:28 PM
