93 honda accord tranny options
Old Sep 9, 2004 | 10:52 AM
iongerz's Avatar
Default 93 honda accord tranny options
I currently have a 93 honda accord ex auto tranny...
I was wondering what 5sp options do i have...
A list that all applies would be great...
i'm planning on going turbo soon on my f22a6
So would it be better to get shorter or longer gears?
Old Sep 9, 2004 | 01:22 PM
91wagon's Avatar
Default Re: 93 honda accord tranny options (iongerz_accord)
Well you can take a 5 speed tranny off of another f22 or put a 5 speed from an h22 on it.
Old Sep 9, 2004 | 01:30 PM
iongerz's Avatar
Default Re: 93 honda accord tranny options (91wagon)
from what model h22?
i heard that you can't use the SH one.. cuz of LSD or sumthing...
Old Sep 9, 2004 | 02:03 PM
drkshdw107's Avatar
accually...what i've heard is that if you are going turbo on your engine...you might want to stick with a 5 speed f22 tranny because it has taller gear ratios...but you can use any H or F series tranny's except the SH prelude...something to do with the differential...i think its electronic or something...not sure...but there are H series trannys with LSD's that you can use.
Old Sep 9, 2004 | 02:05 PM
iongerz's Avatar
Default Re: 93 honda accord tranny options (drkshdw107)
good ****... i'm on it... now i just need to find a f22 5spd tranny...
Old Sep 9, 2004 | 07:34 PM
drkshdw107's Avatar
check the local junk yards...you can usually find them there...but also make sure you get everything you need for the swap...clutch pedal, brackets, fluid reseviour & lines, master cylinder, slave cylinder...i think the axles might be different...but not sure...you might want to do some research on that...if you have high miles on your car (100k+) you might not want to get a lightened flywheel or a super bad azz clutch and pressure plate until you rebuild the engine...you can cause more problems for yourself than what its worth...oh...and keep track of your trans bolts and where they go...some are longer than others and wont fit in the other holes.
Old Sep 10, 2004 | 07:38 AM
iongerz's Avatar
my car was given to me from my mom.. she gave it to me a year ago with only 50k on the car.. she didn't work far
Now i got the car and it gots 89k
thanks for the info though...
Old Sep 10, 2004 | 07:52 AM
iongerz's Avatar
would anyone know if the axels are the same for the auto and 5spd?
BryantReyes
Transmission & Drivetrain
Mar 27, 2015 09:45 PM
h22PreludeSi
Sep 25, 2006 09:52 PM
hot93honda
Dec 12, 2004 09:36 PM
greenli0n25
Apr 17, 2003 09:29 AM
screamer7
Jul 23, 2001 11:46 PM
