fuxorz!
Old Sep 9, 2004 | 07:06 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default fuxorz!
I have a problem, I was checking my timing belt, and I had the valve cover off to get the upper belt cover off, which I took off no problem.Well I put the valve cover back on, and I was tightening the bolts down...and made a big rookie mistake. I was talking to my friend at the same time while tightening the bolts down, and they werent very tight at all (wasnt paying too much attention) so i tightened them a little more and I snapped off the front middle valve cover bolt ... So thats the problem. Now what is the best solution you guys think would be to fix it? Where the bolt snapped, it isnt even flush, its recessed into the hole a little bit.
1) Should i tear everything apart to get the cam cap out and replace that?
2) Or should i just go buy a new motor (no sorry not some crazy b20vtec yet) I can get another d16y7 long block for 100 bucks, and throw it in, it has less miles on it and was in an automatic civic, and i know for sure that it wasnt driven hard..
3) OR maybe i can some how reverse the broken bolt out and just replace that bolt?
Im thinking that i won't be able to just buy one cam cap, im thinking i will have to buy them all which will cost probably more than the long block, and im in need of some advice, so what do u guru's think?
CLIFF NOTE: made rookie mistake by not paying attention, broke off valve cover bolt,
what is the easiest solution to fix it? buy extra motor, tear down head and replace caps, or somehow drill it out?
TIA guys
Old Sep 9, 2004 | 07:17 AM
manson's Avatar
Default Re: fuxorz! (b2o-vtec)
ez out kit should do it. Those bolts are only supposed to be 7-12 ft/lbs if i remember correctly..no manual in front of me..its not very much at all....no wrenching on them.
Old Sep 9, 2004 | 07:31 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
Default Re: fuxorz! (manson)
the easy out kit huh? i htink i ll have to make a quick trip down to kragens/autozone and see if they have it, thanks for that info
Old Sep 9, 2004 | 09:32 AM
PlastikOwl
Guest
Posts: n/a
you're talking about the bolts that hold the valve cover one? Kinda like a long post right? Just take off the valve cover if that's the case and where it screws into the head there is another flange where you can get a wrench around it. Should take 5 minutes at the most.
Old Sep 10, 2004 | 02:42 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
Default Re: fuxorz! (PlastikOwl)
the bolt broke off underneath that flange also i bought the ez out kit, and im going to have my dad use the kit because i trust him more than i trust me will drilling out screws, so hopefully tmw my car will be fixed
stupid me
Old Sep 10, 2004 | 08:19 AM
PlastikOwl
Guest
Posts: n/a
careful with the threads.... Steel > Aluminum.
dont want to strip them out.
Old Sep 14, 2004 | 02:01 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manson &raquo;</TD></TR><TR><TD CLASS="quote">ez out kit should do it. Those bolts are only supposed to be 7-12 ft/lbs if i remember correctly..no manual in front of me..its not very much at all....no wrenching on them.</TD></TR></TABLE>
DUDE thanks man ! to the EZ out kit, worked like a charm! thanks for the lil info
car is fine and dandy now, (and thats not a girlie saying )
Kuhniee
Mar 11, 2010 12:15 PM
jared99
Aug 7, 2006 07:06 AM
idriveadelsol7
Dec 18, 2005 12:23 PM
bartek_b
Apr 15, 2003 11:21 AM
tylerdurden
Sep 8, 2002 09:09 AM
