ITR cluster / dash in 91 CRX
Old Dec 7, 2001 | 11:31 AM
Cre's Avatar
Cre
Default ITR cluster / dash in 91 CRX
http://www.celica.net/john/cre/crx/pages/test_fit.htm
Almost done .... just gotta figure out some of the wiring.
Ill post more pics when i get the car back from the body shop.... Its taking on a new color right now.
Old Dec 7, 2001 | 02:03 PM
badCRX's Avatar
New User
Default Re: ITR cluster / dash in 91 CRX (Cre)
Starting to look good. Keep us updated, I may do that as well. Just call me a biter!
Old Dec 7, 2001 | 04:38 PM
Magick211's Avatar
Default Re: ITR cluster / dash in 91 CRX (badCRX)
That is gonna look really good when its finished. I want to put a new civic dash in my hatch it would be tight
Old Dec 7, 2001 | 10:03 PM
BIG RICH's Avatar
looks good
Old Dec 7, 2001 | 11:20 PM
91ED7Si's Avatar
are you going to be able to fit door panels or are you gonna leave them off?
Old Dec 8, 2001 | 01:53 PM
Cre's Avatar
Cre
Default Re: ITR cluster / dash in 91 CRX (91ED7Si)
No door panels ... the doors have been gutted and painted.
Old Dec 8, 2001 | 02:24 PM
mini-cRx's Avatar
can you help me how did you do it thanks
Old Dec 8, 2001 | 10:34 PM
Piston_Honda's Avatar
New User
Default Re: ITR cluster / dash in 91 CRX (mini-cRx)
How long did it take you to get that far?
Mahalo
Old Dec 9, 2001 | 08:39 AM
Cre's Avatar
Cre
Default Re: ITR cluster / dash in 91 CRX (Piston_Honda)
two days...
Old Dec 9, 2001 | 12:22 PM
mini-cRx's Avatar
can you help i want to do that how would i do that thanks
Old Dec 9, 2001 | 04:49 PM
MysteryWagon's Avatar
how much didi you get the dash for and cluster for?
Old Dec 9, 2001 | 06:58 PM
Mugen Dom's Avatar
nioce get the teg steering wheel from the jdm type r that would be hot ****
Old Dec 9, 2001 | 07:39 PM
QWKPHKR's Avatar
looks good so far man... i already did the swap to my car, i put in a 99 type R dash (cluster, armrest etc). The pictures are from when i had the dash like half way completed, man was it a bitch..i had made some mounts for it so it sits sold, doesn't vibrate at all, it's better then my stock dash actaully.. everything works, all of the gauges, heater controls, vents all line up.. i recently got the doors redone to fit with the dash.. love it.. ohh ya.. i also moved the ignition to one of those pod things in the dash because the ignition is in the way, and it stops the dash from being centered in the middle of the car... it was a bitch but it looks way beter.. If ya need any help with yours let me know...
Here's some pics..
http://24.150.3.161/Dsc00001.jpg</a> http://24.150.3.161/Dsc00002.jpg</A> http://24.150.3.161/Dsc00003.jpg http://24.150.3.161/Dsc00004.jpg http://24.150.3.161/Dsc00005.jpg http://24.150.3.161/Dsc00006.jpg http://24.150.3.161/Dsc00007.jpg http://24.150.3.161/Dsc00008.jpg http://24.150.3.161/Dsc00009.jpg http://24.150.3.161/Dsc00010.jpg http://24.150.3.161/Dsc00011.jpg http://24.150.3.161/Dsc00012.jpg http://24.150.3.161/Dsc00013.jpg http://24.150.3.161/Dsc00014.jpg http://24.150.3.161/Dsc00015.jpg http://24.150.3.161/Dsc00016.jpg http://24.150.3.161/Dsc00017.jpg http://24.150.3.161/N7031.jpg <A HREF="http://24.150.3.161/n7a.jpg" TARGET="_blank">http://24.150.3.161/n7a.jpg <A HREF="http://24.150.3.161/n7b.jpg" TARGET="_blank">http://24.150.3.161/n7b.jpg
[Modified by QWKPHKR, 4:42 AM 12/10/2001]
Old Dec 9, 2001 | 07:42 PM
big pete's Avatar
Default Re: ITR cluster / dash in 91 CRX (QWKPHKR)
tight
Old Dec 10, 2001 | 07:28 AM
WuShu's Avatar
New User
Default Re: ITR cluster / dash in 91 CRX (big pete)
How much did you guys get the dashes for? where from? Did everything line up? what exactly did you guys have to do? any custom fabrication? clearance issues?
Old Dec 10, 2001 | 09:47 AM
QWKPHKR's Avatar
Default Re: ITR cluster / dash in 91 CRX (HondaCRX)
I paid about 350can for my dash which included everything (ITR cluster, airbag, wiring harness, armrest,etc)pretty much everything. Got it from a buddy . No way did the dash line up.. I did a lot of cutting of the dash to make the same curve of the CRX dash, What i did was trace out the CRX dash on a piece of cardboard and cut it out, and then tapped the cardboard on the ITR dash and then cut what wasn't needed.. All of the old CRX venting was ripped out of the car because the ITR dash already had venting on the dash. The ignition was moved to allow the dash to be perfectly centered in the car, if it isn't moved you will have problems inserting your key and the dash will look like ****. I made 4 mounts which hold the dash pretty damn solid (no moving) the wiring was the easiest part of the job, except for getting the speedo to work on the electronic gauge cluster, because the CRX's have a cable speedo, and all 92+ honda's have an electronic VSS.. so all in all it was a bitch, but it was well worth the effort..
If anyone else needs some help msg me and i'll be glade to help you out...
Later
Old Dec 10, 2001 | 10:10 AM
Cre's Avatar
Cre
Yeah looks good, i just gotta finish the wiring and mounts! But in no way does this dash just fit right in. QWKPHKR if you could email me about what you did for the mounts.
JokerTypeR
Feb 3, 2008 07:35 AM
civic_jdm
20
Mar 21, 2005 12:18 AM
JapJunkie
Feb 8, 2004 11:48 AM
STHPERFORMANCE
Dec 24, 2002 03:51 AM
