what is this on the valve cover
Old Sep 8, 2004 | 08:13 PM
dropd4door's Avatar
Default what is this on the valve cover
what is the name of the part here that plugs into the valve cover because mine broke tonight is running shitty
Old Sep 8, 2004 | 08:35 PM
90DALS's Avatar
PCV.
they are cheap to replace.
Old Sep 8, 2004 | 09:55 PM
Street Ghost's Avatar
Default Re: (90DALS)
Yeah..PCV Valve.
Old Sep 8, 2004 | 10:11 PM
dropd4door's Avatar
thanks... could that be making my car run werid? my air fuel gauge stays in the red everytime it falls out
Old Sep 8, 2004 | 10:15 PM
Default Re: (dropd4door)
Yes, a faulty PCV Valve will make your car run weird, sorta. That's why it's one of those parts you replace whenever u do a tune-up. Also, you wont't be able to pass smog without the PCV Valve.
Old Sep 19, 2004 | 03:05 AM
xAznRac3rx02's Avatar
Default Re: (JDM Ninja)
sorry if this is a dumb question.... but wat does the pcv valve do?? I figured i'd ask since u guys r on the topic
Old Sep 19, 2004 | 08:07 AM
Hawkze_2.3's Avatar
Default Re: (xAznRac3rx02)
It vents the pressure that builds up in the bottom end(crankcase) into the intake manifold through a 1-way valve(PCV). It also lets oil vapors in, which is why a lot of people put a catch can between the PCV valve and the IM...
erikiksaz1
Engine Management and Tuning
Sep 25, 2011 09:37 PM
Black R
Jan 25, 2010 07:18 PM
91EF919
Jun 14, 2009 02:07 AM
Bioinfomatic
Feb 23, 2007 04:15 PM
Ri5e
Aug 11, 2002 03:28 PM
