lowering tha accord
if i lower my 93 accord 4 door am i gonna have to buy a chamber kit right away or can i get buy with out having to get one at all i got 17 inch rims and i wanted to get ajstible coil overs and lower it pretty much as low as it can go with any rub...so what do u guys think? thanks for your help
Just a quick question:
Why are you wanting to lower it as much as possible? It is for asthetic purposes or handling?
If its for handling...it won't handle any better if your car is sitting on the ground; yes you lower the center of gravity of the car BUT a nice shock/strut, sway, spring, strut tower braces a "mild to medium" drop will do just as nice AND you won't go through tires as easy. NTM the camber kit will actually be able to adjust the camber you created from having a mild to medium drop (1-2inches).
Just my 2 cents
Just my 2 cents
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doug pollom 93 accord »</TD></TR><TR><TD CLASS="quote">if i lower my 93 accord 4 door am i gonna have to buy a chamber kit right away or can i get buy with out having to get one at all i got 17 inch rims and i wanted to get ajstible coil overs and lower it pretty much as low as it can go with any rub...so what do u guys think? thanks for your help</TD></TR></TABLE>
There's a point of dimminishing returns when it comes to lowering your vehicle. For one, you can really damage the underside of the car (you will always find yourself in the middle of bad roads - been there, done that). It's also very hard on your axles - having it so low puts the axles at a bad angle instead of being straight, causing twice the stress on the joints.
Anything more than a 2" drop is not worth it on an accord unless you're at a car show.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doug pollom 93 accord »</TD></TR><TR><TD CLASS="quote">ya so what kinda kit would u get? im guessing tha 29 dolla ones off ebay arnt very good?
Correct....read the "basic guide" it will answer a LOT of the questions you may have
Guest
Posts: n/a
I'm just curious. HOW MANY TIMES A WEEK CAN THIS POST POSSIBLY APPEAR?
Also curious, is the search feature still available to trial users? Seems like every mother ****** that jumps on here to make 1 or 2 posts is asking about how to lower, how much to lower, and will I need a camber kit.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord »</TD></TR><TR><TD CLASS="quote">Bag it y0!
**** it, CUT THE DAMN SPRINGS
</TD></TR></TABLE>**** it, CUT THE DAMN SPRINGS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner »</TD></TR><TR><TD CLASS="quote">
thats the worst idea ever....forget about springs all together, ride on shocks alone, mad tyte ride y0!
</TD></TR></TABLE>thats the worst idea ever....forget about springs all together, ride on shocks alone, mad tyte ride y0!
Eibach Pro kit is a good set of springs. Tein also makes the S-Tech.
Both I would recommend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner »</TD></TR><TR><TD CLASS="quote">I'm just curious. HOW MANY TIMES A WEEK CAN THIS POST POSSIBLY APPEAR?
ohh you didn't get that memo? It is invisible to trial users.
</TD></TR></TABLE>ohh you didn't get that memo? It is invisible to trial users.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lostcb7 »</TD></TR><TR><TD CLASS="quote">
thats cuz they dont know ****...
my car has an ingalls camber kit right now, its perfect, get an ingalls.
</TD></TR></TABLE>thats cuz they dont know ****...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe »</TD></TR><TR><TD CLASS="quote">
my car has an ingalls camber kit right now, its perfect, get an ingalls.</TD></TR></TABLE>
Bah!
<----no camber kit(my tires wouldnt clear if i had one) just fine
Bah!
Becky T
Mar 4, 2011 09:20 AM
OdysseyHF
Nov 29, 2003 07:25 AM
