will D series bolts hold a flywheel on a B series engine?
Old Sep 8, 2004 | 04:15 PM
91teg's Avatar
Default will D series bolts hold a flywheel on a B series engine?
same as topic. Thanks
Old Sep 8, 2004 | 04:26 PM
C uR eX's Avatar
Default Re: will D series bolts hold a flywheel on a B series engine? (91teg)
i'm not sure i got the question
but are you asking if a D series flywheel bolts be able to use on a B series motor? if the the case then as long as the flywheel bolts are froma 5spd and not from an automatic then yeah, it will.
Old Sep 8, 2004 | 04:28 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: will D series bolts hold a flywheel on a B series engine? (C uR eX)
If the bolts are the same size, and have the same threads.. then yes.
Old Sep 8, 2004 | 04:33 PM
EP3_05's Avatar
Default Re: will D series bolts hold a flywheel on a B series engine? (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">If the bolts are the same size, and have the same threads.. then yes.</TD></TR></TABLE>
exactly....
Old Sep 8, 2004 | 04:40 PM
91civicEX's Avatar
Default Re: will D series bolts hold a flywheel on a B series engine? (91civic)
i think hes asking if the D series bolts are the same thread and size as the B series bolts
Old Sep 10, 2004 | 02:41 AM
91teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">i think hes asking if the D series bolts are the same thread and size as the B series bolts</TD></TR></TABLE> yes. are the auto bolts different from the manual ones? I bought a B16 auto, and tought i got a manual. I have the flywheel and clutch to go with it, but no flywheel bolts. is the crank the same? Thanks
Old Sep 10, 2004 | 06:46 AM
EP3_05's Avatar
The crank is the same on the auto and manual b16a's.
Old Sep 10, 2004 | 07:03 AM
HighVelocity's Avatar
d series bolts are different then b series bolts and automatic bolts are all the different. the lenght of the bolts are different and also the torque specs on them are different also
Old Sep 10, 2004 | 07:46 AM
DonF's Avatar
Default Re: will D series bolts hold a flywheel on a B series engine? (HighVelocity)
D series bolts are shorter than B series and should not be used, get new B bolts from Acura.
Old Sep 10, 2004 | 09:56 AM
bambam's Avatar
Default Re: will D series bolts hold a flywheel on a B series engine? (DonF)
yes...get the new bolts from acura.
there like 8.xx something a piece.
rodvang
Sep 26, 2007 11:49 AM
rasinhell
11
Aug 16, 2005 12:20 PM
Boosthead
Dec 30, 2004 08:13 AM
14bcoupe
Dec 14, 2004 02:45 PM
