Question About Putting on a Type R Header onto a B18B Motor!
Old Sep 8, 2004 | 03:14 PM
Saito's Avatar
Default Question About Putting on a Type R Header onto a B18B Motor!
*Does anyone know if a type r header can fit on to a b18b ls motor? i heard it can't! is that true?
Old Sep 8, 2004 | 03:41 PM
purplegsr's Avatar
Default Re: Question About Putting on a Type R Header onto a B18B Motor! (Saito)
it can, you just need to modify the length of your cat or exhaust piping so it bolts up and put on a cat flange that can handle a 2.5 in collector.
Old Sep 8, 2004 | 04:08 PM
ponytd's Avatar
Default Re: Question About Putting on a Type R Header onto a B18B Motor! (purplegsr)
yeah it will fit with some slight modifications like pruplegsr said
Old Sep 8, 2004 | 04:41 PM
Padawan's Avatar
Darth ModerVader
The above replies are correct, assuming you're talking about the JDM ITR 4-1. If you simply mean the stock USDM ITR exhaust manfold (or any USDM header made for the ITR), then it will install with absolutely no modifications.
Bango_Vang01
Dec 11, 2008 10:36 PM
deadbeat
May 9, 2005 12:41 AM
Race Egr
Mar 8, 2004 07:06 AM
Sohc Driver
Feb 5, 2003 12:26 PM
speedevo
Aug 28, 2002 01:14 PM
