we put my block together and the pistons (JDM Type-S) pop up out of the block... question inside!
Old Sep 8, 2004 | 02:55 PM
crdcz03's Avatar
Fortune Cookie Member
Default we put my block together and the pistons (JDM Type-S) pop up out of the block... question inside!
the piston doesnt pop out... but the dome part is sticking out above the block when the pistons are at the maximum height. so my question is... will they hit the valves?
im pretty sure people have done this before but i was just wondering if it's always like this?
oh and its h23 crank and rods with JDM H22 Type-S pistons. so if any of you have that setup then id really appreciate your input.
Old Sep 8, 2004 | 05:02 PM
crdcz03's Avatar
Default Re: we put my block together and the pistons (JDM Type-S) pop up out of the block... question inside
bump
Old Sep 8, 2004 | 05:04 PM
4bidden's Avatar
I thought the S pistons were floating wrist pin and the H23 rods aren't....so how'd ya do that?
Its fine if the dome sticks above, as it pretty much always will with an 11:1 piston.
Old Sep 8, 2004 | 06:09 PM
spnbb2
Guest
Posts: n/a
high comp. pistons
satan_srv's Avatar
uh...the dome is supposed to stick out of the block...
can you measure the piston to deck clearance? thanks.
(outer edge of piston at TDC to top of block)
Old Sep 8, 2004 | 06:33 PM
crdcz03's Avatar
h23 rods were rebushed. they are now compatible with floating pistons
satan_srv: if i go over to my mechanics house tomorrow or the next day i shall measure that. (and thanks for breaking it down for me... im still learning the official terms of the engine hahaha). oh and i realize they were supposed to stick out i guess the dome just looked bigger when the pistons were installed in the block rather than outside the block.
i will also retrieve my memory stick from my sisters apartment before i go over there b/c she stolenated her memory stick back from me hahah
Old Sep 9, 2004 | 12:49 AM
PirateMcFred's Avatar
I measure the compression height of some H22 pistons I have at 1.223" and my H23 pistons at 1.193". That is a difference of 0.030". On my H23 block I get H23 pistons 0.012" in the hole. So through a little math the Type-S pistons should be about 0.018" out of the hole in an H23 VTEC. That is of course at the edge of the piston and not at the center. But that is just calculation so if you take the block to get it checked it would be great to get real data. Let us know...
Pirate
ivan93egreppin210
Jul 9, 2012 06:43 AM
REDLUDE4WS
Feb 21, 2011 12:25 PM
tmrtwo
Jan 4, 2007 05:35 PM
WiteSiprelude
Jul 26, 2005 10:27 AM
JDM_4thGen
Jun 26, 2002 10:59 AM
