DOHC ZC into 4dr EF civic sedan
Old Sep 8, 2004 | 02:03 PM
NorcalHB94's Avatar
Default DOHC ZC into 4dr EF civic sedan
i was wondering if this is a straight drop-in like the coupes/hatch and also does swapping this motor into the sedan have the same problem with the timing belt rubbing on the hood? thanks.
Old Sep 8, 2004 | 02:06 PM
John McClane's Avatar
Default Re: DOHC ZC into 4dr EF civic sedan (NorcalHB94)
negative
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorcalHB94 &raquo;</TD></TR><TR><TD CLASS="quote">problem with the timing belt rubbing on the hood?</TD></TR></TABLE>
Old Sep 8, 2004 | 02:13 PM
NorcalHB94's Avatar
so it should fit just fine?
Old Sep 8, 2004 | 02:19 PM
EP3_05's Avatar
It will fit just fine. I had a zc in my 4dr a few years back.
Old Sep 8, 2004 | 04:01 PM
1990civicsiguye's Avatar
well that is not entirly true . you will have to cut the hood supports or just trim them off to make it like a bug in a rug
Old Sep 8, 2004 | 04:19 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (1990civicsiguye)
Don't cut up the hood supports. Put 2 washers underneath the drivers side mount.
EP3_05's Avatar
I did not have to cut my hood webbing. The ZC fit in my engine bay without any rubbing.
Old Sep 10, 2004 | 06:12 PM
hatchinprogress's Avatar
Default Re: (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Don't cut up the hood supports. Put 2 washers underneath the drivers side mount. </TD></TR></TABLE> or you could just take off the timing belt cover. it looks nice if you have aftermarket gears
BigbamaBen
23
May 2, 2012 05:36 PM
EF_ST@TUS
Jun 1, 2007 07:49 AM
HondaKPX
Aug 17, 2004 02:26 PM
adnoh90Civic16
Sep 7, 2003 08:09 PM
JackAcc
16
Jul 13, 2003 02:04 PM
