What will divert power away when a motor is fully extended to stop damage?
I don't know how to word this, but here's my best shot. I'm asking in here because you guys that are familiar with wiring will hopefully know exactly what I'm talking about.
On say an OEM power window setup. When you push the switch to roll the window up and the window gets all the way to the top, what diverts the power away from the motor so that the motor doesn't continue to churn?
Something keeps power away from the motor because the motor doesn't even go....something diverts or bypasses the current.
What does that? How can I wire something like that into a circuit?
I need something to divert power away from a motor when the motor has met it's full extension, as to avoid damage to the motor but that will allow the current to return if the switch is flipped the OTHER way (i.e. up and down).
What am I looking for!? Is this something I can buy, or something I can do with the wiring to achieve this?
latching relay and a pair of lilmit switches....limit switches will tell the relay to cut the power, relay will control the motor via a momentary switch.
Okay, that makes sense.
Is there a way to wire that up in conjunction with an OEM style switch?
Here's a little in-depth discussion of what exactly I'm trying to do:
https://honda-tech.com/zerothread?id=984347
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">I don't know how to word this, but here's my best shot. I'm asking in here because you guys that are familiar with wiring will hopefully know exactly what I'm talking about.
What am I looking for!? Is this something I can buy, or something I can do with the wiring to achieve this?</TD></TR></TABLE> No problem, get yourself a DEI sunroof mod. not sure what model # is, you can trigger it with a switch or the outputs of an alarm, it has "load limit" switch inside, [when motor stops, load gos up power is switched off
94
94
What am I looking for!? Is this something I can buy, or something I can do with the wiring to achieve this?</TD></TR></TABLE>I'm at work now, the part# is DEI 529t or 530t if you want to fully automate it. IM me if you need help.
94
94
bpeters2
Dec 14, 2015 08:31 AM
