plz help!!!
Old Sep 7, 2004 | 08:26 PM
daveid's Avatar
Default plz help!!!
i posted this before but i just cant get any where with it.so sorry but im in desperate need of help.
i have an 86 honda accord and one day i was driving it and pulled over and then restarted it. After restarting it, it died in seconds. After that it wouldnt start. We popped the clutch and it would run at high rpms but after it died again it wouldnt start. I have replaced the cap, rotor, plugs, wires, fuel filters and now the coil, but i just found out im not getting spark even after i replaced the coil...it acts like it really wants to kick over but it just isnt.i have looked at the wires the best i could to make sure none were bad but i dont see nething wrong.Honda said to check the ignition igniter but the guy at the parts store said it wouldnt be that since i can pop the clutch and it starts. THANX FOR ANY HELP!!!
Old Sep 8, 2004 | 06:15 PM
daveid's Avatar
Default Re: plz help!!! (daveid)
no???
Old Sep 9, 2004 | 05:30 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveid &raquo;</TD></TR><TR><TD CLASS="quote">...Honda said to check the ignition igniter but the guy at the parts store said it wouldnt be that since i can pop the clutch and it starts.</TD></TR></TABLE>Sounds like it started by popping the clutch while it was in the process of dying. If you're NOT getting any spark, then you'll not be able to start it by popping the clutch any more. If that's true, the ignitor might be the problem. But don't forget this might have been caused by flaky wiring in the first place.
Old Sep 9, 2004 | 04:56 PM
daveid's Avatar
Default Re: plz help!!! (JimBlake)
well everything is stock on the car and there is 137k on it...so ive tried to see if any wires were cracked or swelled or disconected but i dont see anythign wrong.
Old Sep 9, 2004 | 08:57 PM
sol_guy8569's Avatar
It almost sounds to me like it isn't getting enough fuel. Have you changed your fuel pump? But you say your not getting any spark. Are your plugs good? Are they gapped right?
Old Sep 9, 2004 | 10:06 PM
rev-speed's Avatar
borrow a dist form some one and try it out
hondas have junk dist. (or is it we beat them to death)
anyways the crank angle sensor not reading rite somethings is a normal honda/acura problem
if u can t get a dist. get a smart tech. with a dso to check ur crank and cam angle pluse strength
Old Sep 10, 2004 | 07:14 PM
daveid's Avatar
so should i go ahead and try the ignitor??? I KNOW its getting fuel...i can smell it really bad even when i just crank the engine for a second. the thing im affraid of though is i kinda live in the boonies and i want to do the work myself but i dont have nething for the timing and i dont know much about that...so im hoping its only something like the ignitor....thanx for the help guys
Old Sep 10, 2004 | 10:25 PM
rev-speed's Avatar
check the ignition coil first
Old Sep 11, 2004 | 09:06 AM
daveid's Avatar
just bought one the other day and no improvment.
Old Sep 11, 2004 | 08:39 PM
rev-speed's Avatar
now test ur ignitor
see the two wire connector at the dist.
splice into the blue wire and tap it to ground (lay a test light on the valve cover
wire one side to the postive of the battery and the other to the neg. of the ignition coil) it should light up
Old Sep 12, 2004 | 09:45 PM
daveid's Avatar
thanx...i dont have a tester but ill go buy one and try it...ill let you know if i need more help after that....thanx for the help
new2vtec
11
Jun 27, 2007 12:44 PM
Littlegreend15
Apr 14, 2005 07:53 AM
daveid
Sep 7, 2004 08:21 PM
daveid
Sep 5, 2004 11:34 PM
SI_niki
11
Jun 13, 2004 05:02 PM
