ACT disc question
its actually my friends car he has a DOHC del sol, he has turbo, catback, hi flo cat n something else that i 4get. all i need to knoe is if it will fit
oh, ok so its del sol dohc turbo!!
What motor do you have? (I'm assuming the clutch is on your car)
What motor does he have?
Edit: I think I understand now...
Are you asking will a ACT SS clutch disk work for his turbo car and not slip? It depends on what he does with his car, how much power he makes, and how does he drive it.
You need to find out what Pressure Plate he has. ACT makes 3 diff PP's. HD, XT, and XX.
If you dont want a puck disk, go with the SS disk, but get the XT pressure plate, they are good to over 300 ft pounds of tq. The HD is good to a bit under 250 ft pounds with the SS disk that your talking about.
I edited my post. Now im super confused tho. Whos car needs a different clutch disk, the B series or the D series, and is the clutch disk that you want to get new or used.
Motor-Tek
Aug 9, 2005 05:37 PM
TheShocker
Sep 8, 2001 01:17 PM
