Ls Vtec or B20vtec?
Old Sep 7, 2004 | 06:15 PM
JDMnerd's Avatar
Default Ls Vtec or B20vtec?
hii guys it's come that time to decide on my engine swap.. hmm i dont want a typical GSR engine i was aiming for a LSvtec or a B20vtec .. umm wanted some power but didnt want to spend as much on a GSR .. i did some research found out that it was a little more expensive.. soo i came to this question.. which would u guys consider? a LSvtec or a B20vtec?
can u please give me ur opinions.. thanks guys!
Old Sep 7, 2004 | 06:47 PM
DEVIOUS_EG*'s Avatar
Default Re: Ls Vtec or B20vtec? (JDMnerd)
B20/VTEC
Old Sep 7, 2004 | 07:25 PM
Propulsion's Avatar
Default Re: Ls Vtec or B20vtec? (DEVIOUS_EF*)
either way its going to come out costing just as much if not more than a gsr if you want to do it right.
But of the two I would choose the b20vtec
Old Sep 7, 2004 | 07:27 PM
JDMnerd's Avatar
Default Re: Ls Vtec or B20vtec? (SilverCIVIC96)
kooo kooo .. well keep ur opinions coming =D
Old Sep 7, 2004 | 08:53 PM
ceLtic's Avatar
N/A wh0re!
i would like to know this....if its worth spending 400$ more on a b20 or get the ls for like 600-800$...
Old Sep 7, 2004 | 08:54 PM
PhreeStyleHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* &raquo;</TD></TR><TR><TD CLASS="quote">B20/VTEC </TD></TR></TABLE>
Old Sep 7, 2004 | 09:13 PM
goPHAST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 &raquo;</TD></TR><TR><TD CLASS="quote">either way its going to come out costing just as much if not more than a gsr if you want to do it right.
But of the two I would choose the b20vtec </TD></TR></TABLE>
I agree with SilverCIVIC96.
Old Sep 7, 2004 | 10:18 PM
EMO-anthony's Avatar
b20vtec!
Old Sep 8, 2004 | 05:25 AM
-iLLuZioN-B18C1's Avatar
Default Re: Ls Vtec or B20vtec? (THAiGuYDc2)
i would also say b20z/vtec
just by throwing in some different things at
http://www.c-speedracing.com/h...c.php
say you got a b18b block/ gsr head:
9.73 CR
1834 cc
now if you got b20z block/ gsr head:
10.1 CR
1973 cc
you will get higher compression and a 2 L motor going the b20 route
Old Sep 8, 2004 | 04:57 PM
JDMnerd's Avatar
Default Re: Ls Vtec or B20vtec? (-iLLuZioN-B18C1)
kooo thanx guys!
Old Oct 3, 2004 | 11:27 AM
kaman's Avatar
I have an ls/vtec in my 91 integra, the crank in the 1.8 block is alot stronger than the crank in the 2.0 block, I read an iteresting article in honda tuning about people spinning the bearing because the crank cant handle the high rpms that the vtec heads are meant to put out. whats the sense on going ls/vtec if you cant use the full potential of the head. If you build it right it is better than gsr but i think it will cost more. I also think b18 with b16 head is the way to go over crv. mine hasnt busted yet and i rev it past 8 grand every day. on stock components i ran a 14.9.
Old Oct 3, 2004 | 11:30 AM
The Destroyer's Avatar
Default Re: Ls Vtec or B20vtec? (kaman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaman &raquo;</TD></TR><TR><TD CLASS="quote">I have an ls/vtec in my 91 integra, the crank in the 1.8 block is alot stronger than the crank in the 2.0 block, I read an iteresting article in honda tuning about people spinning the bearing because the crank cant handle the high rpms that the vtec heads are meant to put out. whats the sense on going ls/vtec if you cant use the full potential of the head. If you build it right it is better than gsr but i think it will cost more. I also think b18 with b16 head is the way to go over crv. mine hasnt busted yet and i rev it past 8 grand every day. on stock components i ran a 14.9.</TD></TR></TABLE>
I thought the B20 crank and LS crank were the same?
Old Oct 3, 2004 | 02:10 PM
ArinX's Avatar
ls block resleeved to a 2.0
and yes the ls and b20 crank are the same thing
EDIT for some eye candy.
Modified by ArinX at 9:38 PM 10/4/2004
Old Oct 4, 2004 | 05:47 PM
kaman's Avatar
Default Re: Ls Vtec or B20vtec? (ArinX)
ok im gay, i read somewhere that they werent the same, maby i read 2 much. but my setup is kick *** and strong, i recommend it.
Old Oct 4, 2004 | 06:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX &raquo;</TD></TR><TR><TD CLASS="quote">ls block resleeved to a 2.0
and yes the ls and b20 crank are the same thing</TD></TR></TABLE>
Werd, the B20 also has a different sleeve design.
EDIT: Im retarded I was thinking you said a B20 was a bored out B18.
Modified by Vtaaak y0 at 7:50 PM 10/6/2004
Old Oct 4, 2004 | 07:10 PM
UnKnownUser's Avatar
Ls/vtec what now hahaha
Old Oct 4, 2004 | 08:24 PM
OEMJDM's Avatar
Default Re: Ls Vtec or B20vtec? (LSVTEC ALLMOTOR DC4)
the b20 block has weaker sleeves than the b18 block.
Old Oct 6, 2004 | 05:29 PM
kaman's Avatar
Default Re: Ls Vtec or B20vtec? (OEMJDM)
ok i was thinking b18c and b20 crank, they are different.
Old Oct 6, 2004 | 05:43 PM
Professor15's Avatar
The b20 has a weaker sleeve design since its bored to 84mm but has the same stroke as the ls 89mm, but that doesnt mean you cant build a b20 with stock sleeves that makes power. You also have to consider that you need to build the bottom end so you can rev it safely. It all depends on how much money you have and how much trust you have in your engine builder/tuner.
Old Oct 6, 2004 | 06:46 PM
Default Re: Ls Vtec or B20vtec? (drchulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drchulo &raquo;</TD></TR><TR><TD CLASS="quote">The b20 has a weaker sleeve design since its bored to 84mm but has the same stroke as the ls 89mm, but that doesnt mean you cant build a b20 with stock sleeves that makes power. You also have to consider that you need to build the bottom end so you can rev it safely. It all depends on how much money you have and how much trust you have in your engine builder/tuner.</TD></TR></TABLE>
They arent B18 Sleeves bored out, it is a different sleeve design.
Old Oct 6, 2004 | 06:59 PM
vtecdamian's Avatar
comparing a b18 and a b20 in the all motor categry is like comparing ****...
a b cup is good but a c cup is better but in no way is the b cup bad it just sux when compared to the c cup..... (b20vtec 234 whp all motor) b20vtec =
Old Oct 6, 2004 | 07:00 PM
Default Re: Ls Vtec or B20vtec? (vtecdamian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecdamian &raquo;</TD></TR><TR><TD CLASS="quote">comparing a b18 and a b20 in the all motor categry is like comparing ****...
a b cup is good but a c cup is better but in no way is the b cup bad it just sux when compared to the c cup..... (b20vtec 234 whp all motor) b20vtec = </TD></TR></TABLE>
***** and NA Honda's is where its at.
Old Oct 6, 2004 | 09:43 PM
allmotorb20vtec's Avatar
Default Re: Ls Vtec or B20vtec? (Vtaaak y0)
im running stock b20 sleeves w/ 12.5.1 full season 1100 hard miles from day one and still runs strong, tuned w/hondata s200 system..
Old Oct 7, 2004 | 01:49 AM
mEr's Avatar
mEr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 &raquo;</TD></TR><TR><TD CLASS="quote">
***** and NA Honda's is where its at. </TD></TR></TABLE>
sig material....
i would have to vote for B20/VTEC....
Old Oct 7, 2004 | 02:54 AM
H.A.R.T B18C1EG6's Avatar
Default Re: Ls Vtec or B20vtec? (mEr)
Vote is for B20/VTEC
