weather strip window thingy
hey guys i wanted to know if you kno where i can get these. its the rubber piece under the two windows and i think it protects water from gettting into the door panel when it rains. well mine are not gunna be effective cuz the rubber is weathered cracked and its down to the aluminum base. its supposed to look like rubber strips the seal the window from the outside.
help please? eg coupe? anywhere but direct cuz they're gunna charge me like 100 bux a piece aahahha?
i honestly thought about that, but the thing is, its not gunna do its job cuz it will let water into the door panel.
edit: hey guys i think i found it but im not sure which part number it is cuz the diagram is kidna wierd.
http://www.hondaautomotivepart...PANEL
its that single strip that's between the door shell and the door skeleton
Modified by tofu9000 at 8:13 PM 9/7/2004
well i just called the dealer and honda direct. the dealer guy was cooler. they get them for like 67 bux EACH on special order. i think that's still too much for a little piece of aluminum and rubber. i gotta find a better deal.
part name: Channel Door Run
part number: 72235-SR3-AO1
alright guys, this thing is getting a revival
http://www.hondapartsunlimited.com they got em, and cheap too.
left: 72275-sr0-a00
right: 72235-sr0-a00
thats for a eg coupe
PSUCRX is in parts over there and he's got them so ORDER IT all of ya's
left: 72275-sr0-a00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu9000 »</TD></TR><TR><TD CLASS="quote">i honestly thought about that, but the thing is, its not gunna do its job cuz it will let water into the door panel.
Modified by tofu9000 at 8:13 PM 9/7/2004</TD></TR></TABLE>
close but not quite the right page . . . you need "Front Door Lining"
See #10
http://www.hondaautomotivepart...INING
See #10
wait u sure? so in that diagram its 18/22 ??? cuz this is all interior, im talking about the rubber piece that seals the window from the outside. that seals from the inside i think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu9000 »</TD></TR><TR><TD CLASS="quote">wait u sure? so in that diagram its 18/22 ??? cuz this is all interior, im talking about the rubber piece that seals the window from the outside. that seals from the inside i think</TD></TR></TABLE>
ahh yes you're right. #10 is the inside window seal, not the outside.
si_motor_spt
Aug 1, 2010 02:38 PM
