Advanced Timing affect Emissons?
it will help emissios a little. by concept. if the spark is ignighting sooner, this would cause more of the mixture to burn by the time the exhaust valves open, cause less unburned fuel to reach the emissions sensor. or the OBDII connector reader.
If they just plug it in and you aren't throwing any codes, you're golden.
Otherwise, the more preventative stuff you can do, the better. Fresh oil change, fresh tuneup, and a bottle of injector cleaner through the engine will help things out.
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">How advanced? they will check it I think the tolerance is 2 to 3 degrees</TD></TR></TABLE>
ya its only 2
ya its only 2
Deathwish
May 9, 2005 09:45 PM
