I have a stock f22, what is ideal turbo setup..?
Old Sep 7, 2004 | 04:48 PM
sepulchralx's Avatar
Default I have a stock f22, what is ideal turbo setup..?
I have been interested in turbocharging my car, i know i'll need manifold, flanges, turbo, i/c, piping, injectors, ignition, whatever.
I am looking to run 7-8psi MAX i dont want a fast car just a reliable turbo honda with slim to no detonation
What is the ideal setup? I think i can get the fmic of an EVO V and a t25 turbo pretty cheap. I favor small turbo because of fast spool. Again, i dont want to run lots of boost.
Thanks. Matt
Old Sep 7, 2004 | 09:14 PM
satan_srv's Avatar
Default Re: I have a stock f22, what is ideal turbo setup..? (sepulchralx)
Moved to Accord forum since I think a lot more of these people boost F22s
Old Sep 8, 2004 | 03:26 AM
Default Re: I have a stock f22, what is ideal turbo setup..? (satan_srv)
thanks top
Old Sep 8, 2004 | 08:39 AM
JayFI's Avatar
I have 97 accord SE, and planning the same thing as you. But the hardest part was to find a manifold for my F22B2 engine and now that I finally found 1, it has a T3 turbo flange and not a T25. So now I'm stuck with either finding an adapter plate for the T25 to T3 flange or buy this T28 that has a T3 flange.
My mechanic gave me some advice/info since I'm planning 8lb boost on stock internals ( he assures me I can do 10lb np), to save $, I don't really need an IC. I may put one in later down the road since I am in FL.
So.. good luck to you.
Old Sep 8, 2004 | 09:46 AM
Default Re: I have a stock f22, what is ideal turbo setup..? (Jed Atreides)
yeah man, i just hope i can find all the parts for the setup....good luck to you too man
Old Sep 8, 2004 | 10:23 AM
fw190bvi's Avatar
intercoolers are bling bling!!!....even if its a teenie as one from an old volov or DSM, its worth it to have one, and you can pick a stock one up for dirt cheep at your local junk yard!!....as long as yhe engine is in good shape, and its tuned well, at 6-8 psi, the car should be very reliable
Old Sep 8, 2004 | 11:30 AM
Default Re: I have a stock f22, what is ideal turbo setup..? (fw190bvi)
what would you reccomend for a good but not so expensive fmu....
Old Sep 8, 2004 | 11:51 AM
daich's Avatar
Oh yeah.
Water Injection.
Save your money. forget that intercooler.
Old Sep 8, 2004 | 12:14 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sepulchralx &raquo;</TD></TR><TR><TD CLASS="quote">what would you reccomend for a good but not so expensive fmu....</TD></TR></TABLE>
if good = very reliable and programable, than there isnt one....however theres various ways to tune the fuel curve.......i lost the link, but there was an excellent write up on turboing hondas (specificaly intergra, but itll work for any honda), on the advantages/disadvantages of each method....its all a balance of reliability and tuneabilty vs. $$$$$$$
Old Sep 8, 2004 | 01:05 PM
TxTuner
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sepulchralx &raquo;</TD></TR><TR><TD CLASS="quote">I have a stock f22, what is ideal turbo setup..?</TD></TR></TABLE>
TWIN TURBO!!!! (just to be a smart ***)
Old Sep 9, 2004 | 08:00 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sepulchralx &raquo;</TD></TR><TR><TD CLASS="quote">i dont want a fast car just a<U> reliable turbo </U>honda </TD></TR></TABLE>
Those two words in the same sentence tend to contradict eachother. However, properly set up and maintained you shouldnt have problems. As far as parts go, I do believe http://www.lovefab.com makes a custom manifold for the f22.
Old Sep 9, 2004 | 11:58 PM
JayFI's Avatar
Default Re: I have a stock f22, what is ideal turbo setup..? (92prelude)
Yes, LoveFab do make custom manifold for the F22. But I'm looking for a log cast style for daily drive and they don't make it. They have the welded ones and it's about $900 shipped to me. I know, cuz I contacted them. *shudder
I'm on a tight budget *more shudder
Old Sep 10, 2004 | 07:18 AM
TxTuner
Guest
Posts: n/a
Here within the next couple of weeks there will be a write-up on a "junkyard boosted" f22. VRdrvr is days away from completion and will have us informed shortly.
Old Sep 10, 2004 | 08:50 AM
JayFI's Avatar
Default Re: I have a stock f22, what is ideal turbo setup..? (TxTuner)
Haha, I'll follow yours up after a couple of months, I have to get a timing belt change first.
For anyone who's doing the F22 boost: I'm doing stock internals, so I'm doing only 8psi. My mechanic said the Accord can take 10psi np, but I am not pushing my luck.
Old Sep 10, 2004 | 11:24 AM
awesome, i will definetly take a look at that write-up, that should be very helpful
RACEPAK
Dec 6, 2005 01:48 AM
b18c1wes
Jan 5, 2005 01:48 AM
plkalra
Oct 28, 2004 05:06 AM
rival12
Mar 26, 2004 07:20 AM
IggDawg
Oct 2, 2003 09:52 PM
