fuel filter
Old Sep 7, 2004 | 03:17 PM
Ronin150's Avatar
Default fuel filter
My fuel economy was shot. I only get about 150 miles a tank. My brother works with a mechanic and he said that it might be the fuel filter. I was wondering is that my problem and how many filters are on the car. O yea it's an 89 crx dx. Thanks for any help
Old Sep 7, 2004 | 03:25 PM
mr_valentino20032000's Avatar
Default Re: fuel filter (Ronin150)
umm as far as i know there is just the one on the firewall. Although i have no clue how to get it off..but thats it as far as i know.
Old Sep 7, 2004 | 03:31 PM
Deetz's Avatar
Crazy Honda Guy
Its on the firewall between the charcol filter and your throttle body. 3 bolts are all thats needed to change it. 2 on the filter and ond that holds the filter strap. They are cheap at $15, and should be changed evry 4 years or about 50,000 miles. Its about a 10-15 min job if the engine is cold.
Old Sep 7, 2004 | 03:40 PM
Ronin150's Avatar
Default Re: (Deetz)
Thanks for the help. I hope that's my problem, cause spending $10 every two days sucks.
Old Sep 7, 2004 | 03:45 PM
PlastikOwl
Guest
Posts: n/a
Default Re: (Ronin150)
The two large bolts are a real bitch to get off sometimes...use a wrench to hold the filter in place and another to turn the bolt. Right underneath the bolt you can get a grip on the filter itself. Prepare to curse and go through lots of 4 letter words.
Old Sep 7, 2004 | 03:55 PM
tolnep's Avatar
Default Re: (PlastikOwl)
I just replaced mine. I assumed that I could get the banjos off easily. No way. Have air tools with a small impact ratchet. Tried that. Just turned the thing in the bracket. So.. I disconnected the line to the fuel rail and from the firewall and removed the bracket from the firewall. Underneath the banjo bolts are welded hex nuts. Once out of the car, use a wrench on the welded bolts (I think 21 mm) and use another on the banjo bolts. Outside of the car you have good leverage.
Also this is good because if you don't tighten the banjos enough it will leak. Use the new sealing rings that come with the new filter.
Old Sep 8, 2004 | 12:40 PM
Ronin150's Avatar
Default Re: (tolnep)
There's a garage down the street from me that charges 30 bucks and I have to buy the parts. Do you think it would be best if I just had him do it?
Old Sep 8, 2004 | 02:09 PM
michael O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ronin150 &raquo;</TD></TR><TR><TD CLASS="quote">There's a garage down the street from me that charges 30 bucks and I have to buy the parts. Do you think it would be best if I just had him do it?
It's easy enough to do it yourself if you have any skills with a wrench. I did mine in a few minutes one night.
Old Sep 8, 2004 | 02:18 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (michaelOlson)
Just make sure you hold onto the filter when you start trying to loosen up the bolts. Make sure you have a 21mm wrench to hold it and a 17mm wrench to loosen the bolts.
ek747
Sep 20, 2010 01:30 PM
FloridaCivic
Feb 25, 2007 10:08 AM
coronadrinker
Dec 18, 2006 05:58 PM
philkehn
Nov 4, 2006 01:08 PM
namja9487
Jul 23, 2004 08:41 AM
