Integra front brakes on a CRX
Old Sep 7, 2004 | 02:42 PM
rexnst9's Avatar
Default Integra front brakes on a CRX
Anyone running them? If so what are you using to correct the camber? I am using the front brakes off of a 96 Integra and I have to much positive camber.
Old Sep 7, 2004 | 02:45 PM
EL Vap133's Avatar
Default Re: Integra front brakes on a CRX (Bruce Ward)
I used 90-93 Integra DA knuckles instead of the DC (94-01 Teg) knuckles.
Old Sep 7, 2004 | 03:01 PM
REDBARON's Avatar
Default Re: Integra front brakes on a CRX (EL Vap133)
I also have the DA knuckles, and have no problem.
You're not using the LCA's of the Integra are you? If so, then that's your problem. You're only supposed to use the knuckles and retain your stock LCA's.
Old Sep 7, 2004 | 03:06 PM
crxgator's Avatar
Default Re: Integra front brakes on a CRX (REDBARON)
his problem is he is using the 94+ knuckles, when he should have used the 90-93...
Old Sep 7, 2004 | 03:38 PM
rexnst9's Avatar
Nope I did not change the LCA's all that was used was the knuckles. I realize that the knucles are giving me my postive camber problem. What I would like to try and find out is who are the companies making negative camber kits that will alow me to pull the wheels back in. I have seen the Vision negative A-arm kit for the CRX but they are quite pricey. I have heard there are others making them as well but have been unable to come up with any company names. Thaks for the replies guys. Actually! What are the guys using when they do the ITR conversion on the CRX's are they not runing into the same problem?
Old Sep 7, 2004 | 03:46 PM
crxgator's Avatar
they use a hybrid knuckle/hub consisting of either EX knuckles or DA knuckles with ITR hubs...
a negative camber kit will not fix your problem, it will only add camber...
you need to get rid of those knuckles for the correct ones...
Old Sep 7, 2004 | 03:54 PM
rexnst9's Avatar
Default Re: Integra front brakes on a CRX (crxgator)
I am approx 1deg positive now with these knuckles on the car. These Vision arms are supposed to give a fellow 3 deg of negative camber adjustment. I was thinking that 2 deg would put me at zero so to speak and I could go as much as 1 deg negative with these arms. Now to be honest I really don't know because I have never seen anyone use them but they seem like they will do the job. If not then I guess I will have to make the ole switch around to the 90-93 stuff Thanks again
Old Sep 7, 2004 | 04:03 PM
tRex99's Avatar
Hey it all depends..i have 96 gsr knuckles on my rex because i crashed my car so i had positive camber then i put the gsr knuckles and it was less positive...i didnt have to get a kit to correct it i just went to my local framing and wheel alignment guy and he fixed it...it wasnt so much the camber its the toe..look either way your going to have to get it all aligned so take it in and ask them to check it for you some shops will tell you how much its out for free or 10 bucks...
Old Sep 8, 2004 | 12:38 PM
B16 CRX's Avatar
Default Re: Integra front brakes on a CRX (tRex99)
Just replace the whole suspension to 90-93 integra
Old Sep 8, 2004 | 12:40 PM
93civic_sedan's Avatar
Default Re: Integra front brakes on a CRX (B16 CRX)
My buddy has the 90-93 front brakes in his 1990 HF CRX with and LS swap...
Old Sep 8, 2004 | 12:46 PM
Bserieskllr's Avatar
well if you lower the car you dont have to worry about a camber kit
Old Sep 8, 2004 | 01:00 PM
B16 CRX's Avatar
Default Re: (Bserieskllr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr &raquo;</TD></TR><TR><TD CLASS="quote">well if you lower the car you dont have to worry about a camber kit </TD></TR></TABLE>
What make you say that?
Old Sep 9, 2004 | 11:06 AM
tRex99's Avatar
well because the guy has positive camber so if he lowers the car it might zero the camber out is what he's saying...after i crashes min i replaced the LCA and it was close to zero but still postitive so i dropped it another inch because i wore both the crappy tires out already oin the edge then BAM nigge be straight....thats all he's sayin
nihad
Jul 16, 2009 01:48 PM
fekyoride
Suspension & Brakes
Dec 19, 2007 07:39 AM
UrbanEh
Feb 1, 2007 03:35 AM
turbod16y7vtec
Mar 4, 2003 08:01 PM
made in JAPAN
Dec 17, 2002 08:17 AM
