Anyone got a write up on how to install a crank pulley on a B18C?
Old Sep 7, 2004 | 02:33 PM
AlxSiR7's Avatar
Default Anyone got a write up on how to install a crank pulley on a B18C?
I'm thinking about getting the N1 crank pulley, but I'd like to know what's all involved with un-installing the stock pulley and re-installing the new one. There must be some kind of tool since there isn't that much room.... any help would be appretiated! Thanks...
Old Sep 7, 2004 | 03:37 PM
limpy's Avatar
Default Re: Anyone got a write up on how to install a crank pulley on a B18C? (AlxSiR7)
2 words impact gun
Old Sep 7, 2004 | 07:07 PM
AlxSiR7's Avatar
Default Re: Anyone got a write up on how to install a crank pulley on a B18C? (limpy)
anyone else?? anyone have the n1 pulley???
Old Sep 7, 2004 | 07:48 PM
eda6's Avatar
I got a N1 crankpulley. Impact gun
Old Sep 7, 2004 | 07:52 PM
Runnerdown's Avatar
1. Take the accessory belts off.
2. Impact the bolt off.
3. Wiggle the pulley off.
4. Don't loose the keyway pin.
5. Install new pulley.
6. Tighten the crank pulley with a new bolt ( suppose to but..... )
7. Put proper length belts back on.
Old Sep 7, 2004 | 09:20 PM
Sack Master's Avatar
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">1. Take the accessory belts off.
7. Put proper length belts back on.</TD></TR></TABLE>
Good write up
Old Sep 8, 2004 | 03:35 AM
AlxSiR7's Avatar
Default Re: (Sack Master)
thanks guys
Old Sep 16, 2004 | 07:27 PM
esoterEK..'s Avatar
what's the length?
Old Sep 16, 2004 | 08:39 PM
rev-speed's Avatar
if ur crank bolt has never been taken off before
don t try it! more than likely its stuck!
drive to a shop have then shot it off then back on not so tight.
or u can get a chain wrench to hold the crankpulley
then again i had some thats so tight the crank pulley broke
Old Sep 17, 2004 | 01:56 PM
AlxSiR7's Avatar
Default Re: (EGkwazhimoto)
yeah.. what is the length??
Old Sep 17, 2004 | 02:17 PM
limpy's Avatar
Default Re: (AlxSiR7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">yeah.. what is the length??</TD></TR></TABLE>
of what????
Old Sep 18, 2004 | 07:26 AM
AlxSiR7's Avatar
Default Re: (limpy)
the belt size i'd need to use with the n1 crank to the alternator
Old Sep 18, 2004 | 11:30 PM
limpy's Avatar
the same belt size you took off.
white_panther
Dec 8, 2006 04:47 PM
Fuster_Cluck
Jan 17, 2005 04:16 PM
SuicideSlide
Oct 9, 2004 08:27 AM
david90
Aug 15, 2003 01:15 PM
David G
Sep 28, 2002 12:25 PM
