Which SRP pistons with Drag 3
Old Dec 6, 2001 | 10:02 PM
Next Level Honda's Avatar
Default Which SRP pistons with Drag 3
I'm going to be running a Drag 3 turbo and Zex 75 shot set up on my Integra LS and I was wondering what SRP piston compression I should get?
Also I can use the stock connecting rods because they are good up to something like 600hp right?
Should I replace any other internals?
I also have, AEM pulleys, fuel rail, cam gears, Crower cams and valve springs.
Thanks
Old Dec 7, 2001 | 06:46 AM
rtype11's Avatar
Default Re: Which SRP pistons with Drag 3 (Next Level Honda)
Dude, I live in Toronto also, but I dont smoke crack, who is the idiot telling you to run stock rods? I will slap him in the face.
If that is your setup go with SRP 8.5:1 turbo dish, have your cylinders bore measured first in order to decide to buy stock or overbore for worn cylinders. have you considered sleeving yet or is the block good to 2000HP
Old Dec 7, 2001 | 07:55 AM
FAST94GSR's Avatar
New User
Default Re: Which SRP pistons with Drag 3 (rtype11)
srp's won't handle that boost and juice.
yea get your block sleeved get arp head bolts and go with crower rods and je pistons or arias.
you'll blow that **** into pieces with stock rods and sleeves.
Old Dec 7, 2001 | 08:00 AM
HX_Guy's Avatar
Default Re: Which SRP pistons with Drag 3 (FAST94GSR)
I know someone who was boosting 22 PSI on SRP pistons...why do you say they cant handle it?
ty521825
Sep 10, 2012 06:36 AM
redDAinteg
Jun 27, 2005 05:27 PM
TurboTeG4
Jun 18, 2003 03:47 PM
dohc_Cx
Nov 25, 2001 02:40 AM
