1995 Accord EX Headlight problem (w/pics)
Old Sep 7, 2004 | 11:54 AM
BlakeOPS's Avatar
[deleted].
Old Sep 7, 2004 | 12:39 PM
propwdialogue's Avatar
Default Re: 1995 Accord EX Headlight problem (BlakeOPS)
my guess is that the headlight mounts got all bent up in the wreck. pop the hood and take a look around, take a few pictures. pictures of the back of the headlights would be very valuable in finding and fixing your problem
Old Sep 7, 2004 | 12:57 PM
bodiez's Avatar
Hit the floor!
Default Re: 1995 Accord EX Headlight problem (propwdialogue)
Just got done fixing a frontal imapct accord. You might need to customise some of the pieces to get that stock look. If you want to invest the time, itll be worth it in the end.
Also, do a car fax on it.
Old Sep 7, 2004 | 01:01 PM
Kavehman's Avatar
Not really too sure from the pics, but it looks to me like ur hood alignment is off and not the headlights, u may have to bend the hood into place
Old Sep 7, 2004 | 01:45 PM
hometheaterman's Avatar
The headlight doesn't seem to be in there correctly especially the passenger side one. I can't tell about the hood but it looks off too. I don't think I would have bought a car like that. Did he tell you it was in a wreck before you bought it?
Old Sep 7, 2004 | 02:43 PM
BlakeOPS's Avatar
[deleted].
Old Sep 7, 2004 | 03:23 PM
TxTuner
Guest
Posts: n/a
Hood definitely needs some readjusting, but it won't move enough to cover up those headlight problems. Like they said before, check the mounts and if those are in good shape, you're probably going to need custom mounts.
Old Sep 7, 2004 | 03:34 PM
Default Re: 1995 Accord EX Headlight problem (TxTuner)
well i hadnt thought about the hood, but looking closer, that seems like a very viable option. if it seems like the headlight mounts are ok, you might want to get a whole new hood
Old Sep 7, 2004 | 04:29 PM
Stew Pidasso's Avatar
Looks to me like the lights are def not in the right spot but the hood looks off too. Does anyone know if the 96-97 hoods are the same as 94-95s?
Old Sep 7, 2004 | 05:11 PM
puma1077's Avatar
man, i really hope you got a killer deal on that car, cuz its gonna take alot of money to get it to look good again
Old Sep 7, 2004 | 05:47 PM
BlazeTeck2000's Avatar
Default Re: (puma1077)
from what i see it it a front hit damage cause if you look at the frame of the front left drives side the frame is bent and rusted the other side as well is bent to if you know about hondas you can tell ... this to happen to me and i had to bent it back into place (not a pefect job ) but maid it to look better than it was before untill i took it to the body shop ... $1300 cost me cause i was getting a whole paint job... if you need more info let me know i can help you out
Old Sep 7, 2004 | 08:42 PM
95sihb's Avatar
Default Re: (BlazeTeck2000)
Take the Bumper off, and find all 5 screws holding the headlight inplace and adjust it , Thats what happend to mine when i took off the bumper to but a C.A.I. .and replaced the cracked headlights i had on before. so when I but the new headlights on and put the bumper back on it was totaly off, i took the bumper off again and just adjusted the lights untill they fit correctly.......................hope that helps
Old Sep 7, 2004 | 09:49 PM
PhatboyNYC's Avatar
Default Re: 1995 Accord EX Headlight problem (Stew Pidasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stew Pidasso &raquo;</TD></TR><TR><TD CLASS="quote"> Does anyone know if the 96-97 hoods are the same as 94-95s?</TD></TR></TABLE>
Yes except the 96-97 hoods don't have the front emblem on it.
Old Sep 8, 2004 | 06:11 AM
1illAccord's Avatar
Default Re: 1995 Accord EX Headlight problem (PhAtBoY Si)
ughh i hated that. my headlights were like that. it was my brackets on top. they cracked and snapped. its fine now after i put my black housed lights in. check and see, maybe at night...just turn on u'r headlights a couple of feet away from a wall, or your garage and see if they the main emphasis from the headlights points alot higher or lower than the other, then its gotta be more the headlights and not the hood as much. thats kinda how i started assuming a problem in the beginning. good luck!
Old Sep 8, 2004 | 08:25 AM
EXACCORD95's Avatar
Give me the vin and your email i will check the backround for you.
Old Sep 8, 2004 | 04:25 PM
BlakeOPS's Avatar
[deleted].
Old Sep 8, 2004 | 07:08 PM
EXACCORD95's Avatar
Default Re: Re: (BlakeOPS)
U got mail
Old Sep 8, 2004 | 08:31 PM
ICreamOnNi$$an
Guest
Posts: n/a
nice
Old Sep 8, 2004 | 08:51 PM
KhanhCord's Avatar
Default Re: 1995 Accord EX Headlight problem (ICreamOnNi$$an)
to me they semm kinda off from the fender..got same thing w/ my car..
Old Sep 9, 2004 | 11:01 AM
BlakeOPS's Avatar
Default Re: Re: (EXACCORD95)
[deleted].
20q234
Aug 25, 2011 06:20 PM
jyacoba2009
10
Sep 7, 2009 08:30 PM
standbackimapro
Apr 17, 2008 10:07 PM
smuggy
Feb 28, 2003 06:46 PM
IAIA
Jan 5, 2002 11:24 AM
