how easy is it to replace a clutch??
Old Sep 7, 2004 | 11:47 AM
94solchick's Avatar
Default how easy is it to replace a clutch??
I have a 94 del sol s "1.5l". I think it needs a cluch cuz 4th and 5th are hard to get in. Anyways, the clutch is $140, and with me being poor and all, it would take a while for me to save up to buy the clutch AND get it put in. My boyfriend is good with cars, but I replaced the engine in my old civic and there is no clearance to move the tranny away from the engine without lifting the whole thing out! I was just wondering if anyone knew a somewhat easy way to replace it so I don't ruin my tranny by waiting to save to get it put in. Any help would be wonderful. Thanks
The hottie sol chick
Old Sep 7, 2004 | 11:52 AM
2fast4u831's Avatar
I'm really 2slow
the best way is to remove the 3 mounts(top,front and back) and slide the tranny to the side a little and then drop it. I dont think your clutch is going bad maybe its your synchros. Do you feel a difference in the clutch?
Old Sep 7, 2004 | 11:55 AM
94solchick's Avatar
Default Re: (2FAST4U831)
I just got the car 3 weeks ago, so I don't have much to compare it to. I was thinking the syncros may be going bad, but I was hoping that it was the clutch so I don't have to spend all that money to get it fixed.
Old Sep 7, 2004 | 12:06 PM
spyderracing's Avatar
Default Re: (honda94delsolchick)
Support the tranny with a jack and then COMPLETELY remove the tranny mounts. Should allow enough clearence to slide it left and then drop it. Changing the clutch over is cake, especially if you have an alignment tool (all kits come with one usually). Even if you don't have an alignment tool, you can eyeball it and use your pinky to line it up (worked fine for me ).
Old Sep 7, 2004 | 12:25 PM
94solchick's Avatar
Default Re: (spyderracing32)
Good. I was hoping it was somewhat easy. Since I replaced my engine in my old car, I know where all the mounts are now, and how easy they come off. I guess I need to take the axles and everything off, too. Thanks guys.
Old Sep 7, 2004 | 01:53 PM
Burke's Avatar
Banned
Default Re: how easy is it to replace a clutch?? (honda94delsolchick)
its not your clutch
Old Sep 7, 2004 | 03:35 PM
Relic1's Avatar
Default Re: how easy is it to replace a clutch?? (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">its not your clutch</TD></TR></TABLE>
agreed. Unless the clutch is slipping, your problem lies in the trans.
(there's a write up on how to replace the clutch somwhere on here but I can't find it now)
Old Sep 7, 2004 | 03:43 PM
ej1 pilot's Avatar
Default Re: how easy is it to replace a clutch?? (Relic1)
dont hope its something small when its not, eventually youll probly end up buying both, just a thought
Old Sep 7, 2004 | 03:48 PM
HondaCivicAddict's Avatar
It's not your Clutch. Its your transmission. If it was your clutch u would feel it slip. The transmission is your problem. I had mine replaced for the same reason.It is also alot more expensive than a clutch.
Old Sep 7, 2004 | 04:24 PM
mwieczorek43's Avatar
Default Re: how easy is it to replace a clutch?? (HondaCivicAddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicAddict &raquo;</TD></TR><TR><TD CLASS="quote">It's not your Clutch. Its your transmission. If it was your clutch u would feel it slip. The transmission is your problem. I had mine replaced for the same reason. </TD></TR></TABLE>
me too
Old Sep 8, 2004 | 08:43 AM
94solchick's Avatar
Default Re: how easy is it to replace a clutch?? (mwieczorek43)
Great, can't wait. Maybe I'll try flushing it and putting new oil in it. Maybe it has tranny fluid in it now and it's not getting to those gears or something.
Old Sep 8, 2004 | 09:08 AM
redlinetuning's Avatar
Default Re: how easy is it to replace a clutch?? (94solchick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94solchick &raquo;</TD></TR><TR><TD CLASS="quote">Great, can't wait. Maybe I'll try flushing it and putting new oil in it. Maybe it has tranny fluid in it now and it's not getting to those gears or something.</TD></TR></TABLE>
that was gonna be my suggestion..
Old Sep 8, 2004 | 09:11 AM
94solchick's Avatar
Default Re: how easy is it to replace a clutch?? (redlinetuning)
It's cheaper!
Old Sep 8, 2004 | 09:26 AM
mugensport9's Avatar
if not then look for trannys on ebay
Old Sep 8, 2004 | 11:51 AM
Burke's Avatar
Banned
Default Re: how easy is it to replace a clutch?? (mugensport9)
you can try gm syncromesh or that lucas thick stuff or something. it may or maynot help.
kinoukiita
Jul 24, 2006 09:58 PM
mikeyp5d
11
Nov 22, 2005 10:13 AM
DaMmniTz
Feb 18, 2005 08:54 AM
jbell
Jul 30, 2004 02:32 PM
CimorelliCRX
Dec 15, 2002 04:02 AM
