driving probs!!!
2k si when i'm driving sometime the steering wheel will just start jerking to the right what the *** is that? I have to hold the wheel tight to keep the car from slamming to the right?? trans/axles something someone help me out!
1. ur tranny proally dosnt have LSD (limited slip differiental) which evenly allocates the power to both wheels and allocates to one side when another is slipping (giving both sides same amount of torque).
2. you probably dont have power steering
3. does this happen when you turn? or all the time?
if you have rims or it's lowered, sometimes you don't notice it, but there are ruts in the road from people driving on it so much and it can pull your car a lot. Mine did it, too. not much you can do about it.
yeah its lowered also i checked it out i need not one but both lower ball joints also i neet a tie rod on the driver side. Plus i didn't add before i put a new clutch in recently
HeatherK1989x
Jan 10, 2018 07:21 AM
