It won't start after my little incident last night...
Old Sep 7, 2004 | 03:06 AM
GoobDetailer's Avatar
Default It won't start after my little incident last night...
Well, last night I didn't see a bumper and I hit it--it sheered off my inner fender lining and bumped my fender out of alignment.
I went to start it that night about an hour later and I noticed my battery was very low--but it still started.
And now it's completely dead. I dunno what it would be. Or if my battery and my incident are two different things happening at the same time to make me mad. It's the passenger front wheel well if this helps
Old Sep 7, 2004 | 05:52 AM
Wagonist's Avatar
Default Re: It won't start after my little incident last night... (GoobDetailer)
Maybe you somehow loosened the engine ground? Check where it is grounded to the car and the engine?
Also check your battery connections.
It could be a coincidence.
Old Sep 7, 2004 | 06:40 AM
Atheist's Avatar
Default Re: It won't start after my little incident last night... (Large_Sarge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Large_Sarge &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you somehow loosened the engine ground? Check where it is grounded to the car and the engine?
It could be a coincidence.</TD></TR></TABLE>
Yes, generally speaking if you're car is not properly grounded your battery will drain, so check that.
Old Sep 7, 2004 | 09:41 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
Take a look around under the hood there Goob. Could be a few things from a cracked battery to a broken cable. The battery sits on that side so something may have happened there. Maybe the battery has shifted causing a short, maybe you pinched a wire or peeled the skin off a wire and its touching bare metal in that area.
Old Sep 8, 2004 | 06:25 AM
1illAccord's Avatar
Default Re: It won't start after my little incident last night... (Hondaman56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaman56 &raquo;</TD></TR><TR><TD CLASS="quote">Take a look around under the hood there Goob. Could be a few things from a cracked battery to a broken cable. The battery sits on that side so something may have happened there. Maybe the battery has shifted causing a short, maybe you pinched a wire or peeled the skin off a wire and its touching bare metal in that area. </TD></TR></TABLE>
yeppp. check the battery. and its components.
PatrickGSR94
Aug 8, 2008 09:44 AM
De_tour
40
Nov 29, 2007 12:33 PM
03RSXTypeS
Jul 28, 2007 09:57 AM
tigueremalo
May 23, 2006 10:55 AM
smash fascism
Dec 3, 2005 07:58 PM
