vents blow only hot air
Old Sep 6, 2004 | 11:34 PM
cascaritas's Avatar
Default vents blow only hot air
posted once before but never got any real awnsers , my car blows hot air like if the i had the heater on but i have the control set to cool and the heater core is not even connected . the only thing i can think of is my hood since it is one of those cheap taiwan replacement hoods thhat might be holding in some heat any imput would be apreciated.
Old Sep 7, 2004 | 12:00 AM
jdmh22eg's Avatar
do you have a/c my friend...
Old Sep 7, 2004 | 12:05 AM
EK k kay's Avatar
Default Re: (jdmh22eg)
a/c may need a recharge if you have a/c. Mine needs a recharge so it only blows in the air from outside.
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: vents blow only hot air (cascaritas)
look and see if the arm on the coolant shut off valve to the heater core is closing.. the cable could have slipped, and its still open all the time..
or just to diagnose it.. you could pinch off each coolant hoses into the heater core, and see if its still blowing hot air. (no more hot water going into the heater core)
Old Sep 7, 2004 | 04:18 AM
mugenhatch92's Avatar
yeah its called no ac lol
jk
Old Sep 7, 2004 | 08:31 AM
cascaritas's Avatar
Default Re: (mugenhatch92)
i dont want cold air but at least air at out side temp and like i said the heater core is not even connected so there is no hot colant going inside of thhe car .
Old Sep 7, 2004 | 08:54 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: (cascaritas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cascaritas &raquo;</TD></TR><TR><TD CLASS="quote">i dont want cold air but at least air at out side temp and like i said the heater core is not even connected so there is no hot colant going inside of thhe car .</TD></TR></TABLE>
it must be hot outside then...
Old Sep 7, 2004 | 10:59 AM
CivicFreak's Avatar
go to a shop and check for AC leak. recharge if possible. but for true racer, leave the AC out. Weight reduction is always a good thing. don't bother with AC. Never use mine.
Old Sep 7, 2004 | 11:11 AM
idteg's Avatar
Default Re: vents blow only hot air (CivicFreak)
I had the same problem when I bought my 94 coupe a couple months ago. I took it to a shop & they wanted $70 to look for a problem plus whatever else it would cost to fix it. One shop even told me that I needed a whole new a/c system.
It ended up being the cable that is hooked to the heat/cold controller inside my car has been "stretched" out. I have to reach under the dash & switch it myself. I was relieved when my husband showed me that--now I'm thankful that I dont have to ride in a sauna when its raining or pay a high price for a "new" a/c system that I dont need........yes I know my A/C needs charged, but I dont have the extra $$$ for it.
Good Luck
Old Sep 7, 2004 | 09:20 PM
acurasolution's Avatar
can i get a jdm motor legally smog..?
Old Sep 7, 2004 | 09:45 PM
Built B16A's Avatar
Default Re: vents blow only hot air (acurasolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurasolution &raquo;</TD></TR><TR><TD CLASS="quote">can i get a jdm motor legally smog..?</TD></TR></TABLE>
are you serious? we're talking about hot vent temps, and AC's... when did we discuss about BAR'ed JDM engines?
search for topics on BAR, and JDM smog.. its been covered plently of times..
Old Sep 7, 2004 | 09:48 PM
Archidictus's Avatar
Unceasing Measure
Hey moron, do you have air conditioning? If not, did you break your temp. indicator lever when you were thrashing around in a 10-second-run-victory-dance? With NAWZZ? What do you mean your heater core "isn't connected"? And how is it that you think the manufacturer of your hood has anything to do with the air coming into your vents?
If I solved your problem, or even made it more difficult, I fully expect you to let me **** your mom.
Old Sep 8, 2004 | 07:15 AM
cascaritas's Avatar
Default Re: vents blow only hot air (Archidictus)
dumb **** so suck on ur moms baby *****
thanxs to everyone else who tried to help, and the reason i think it migght be my hood is cause it gets really hot and my whole engine bay gets hheat soaked i cant even put my hand on anything inside the egine bay. i disconnected the heater core because when i searched many people said that i could be the valve so if i dont have fluid going thru it then the valve should not even be an issue but air still comes out really hot .
Old Sep 8, 2004 | 08:23 AM
nocturnaldragon's Avatar
Dude what the hell was that all about? your such an ***
First off im sure what he did was disconnect the heater lines and got a U shaped piece of pipe from the hardware store and looped the lines togther. or better yet just put a valve in there so he could just shut it off manually when he needed too. i did that once with an old pos car i had with a popped heater core cause i dident have the time to change it out nor the money so i made due with what i had. Ahhh yes No heat in a cold *** winter. I LOVE WISCONSIN! (sarcasim)
Old Sep 8, 2004 | 08:27 AM
hatchling37's Avatar
Default Re: vents blow only hot air (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Dude what the hell was that all about? your such an ***</TD></TR></TABLE>It's Not Flaming, It's An Education
Old Sep 8, 2004 | 09:22 PM
Built B16A's Avatar
Default Re: vents blow only hot air (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">It's Not Flaming, It's An Education</TD></TR></TABLE>
lets take it a step further.. its common sence.
Old Sep 19, 2004 | 07:42 PM
RXchencho's Avatar
bump for a cool dude
Old Sep 22, 2004 | 06:50 PM
pudgee2006's Avatar
Default Re: vents blow only hot air (RXchencho)
bumb for an o.k guy, good seller!
JeeK
Honda Civic (2001 - 2005)
Dec 21, 2014 08:03 AM
SLPN H
Dec 11, 2006 04:29 AM
bigslimdog
16
Jan 27, 2004 02:51 PM
Conechaser
Oct 2, 2001 01:00 PM
