y8 tranny with gm synchromesh questions (kinda long)
Old Sep 6, 2004 | 10:48 PM
a1320honda's Avatar
Default y8 tranny with gm synchromesh questions (kinda long)
i got a 98 y8 tranny with about 40k off of ebay. the ad listed a slight grind going into 3rd at high rpm. so i put it in and its a pretty substantial grind even at low rpm. so i bought 2 quarts of gm synchromesh and put those in. since then ive gone about 100 miles or so and its getting better. especialy after i get off the highway after about 30 miles or so, theres no grind at all then. but when it cools back down its just a little scratch going in. my questions. will the synchromesh make this go away. also will replacing the clutch help at all. ive read that it takes about 5-600 miles for it to really start working. also, if id doesnt completely go away, will the slight 3rd grind hurt anything. any info is appreciated. the car does go to the track often, but not since the tranny as i was a little nervouse about it.
Old Sep 6, 2004 | 11:15 PM
deviant1's Avatar
Default Re: y8 tranny with gm synchromesh questions (a1320honda)
the synchromesh is just a band-aid solution. replace those synchros/gears
Old Sep 7, 2004 | 12:28 AM
Nerologic's Avatar
Default Re: y8 tranny with gm synchromesh questions (deviant1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">the synchromesh is just a band-aid solution. replace those synchros/gears</TD></TR></TABLE>
yeah its a band-aid, but that patch-up has helped my tranny out for the past 10k miles
Old Sep 7, 2004 | 12:41 AM
JDMlyfestyle's Avatar
ya no doubt. Friend had a Grind in 4th and we put some in right away and a year later still a grind once in a blu blu blu moon.
Old Sep 13, 2004 | 12:14 PM
THMotorsports's Avatar
Default Re: (JDMlyfestyle)
Just picked up the modified Synchromesh, gonna put it in. Btw, did you guys use the modified or the regular?
Old Sep 13, 2004 | 01:11 PM
a1320honda's Avatar
Default Re: (Truehondacom)
i use the friction modified
elcangripapi
45
Apr 15, 2007 08:30 PM
elcangripapi
Apr 15, 2007 08:40 AM
CIVIC96DXcp
May 1, 2005 07:20 AM
95cxhatch
Jan 6, 2004 08:04 AM
ASHY-ELBOW
Nov 4, 2003 12:36 PM
