Making aluminum heat sheild/air box for intake
Old Sep 6, 2004 | 10:33 PM
NiceDc2r's Avatar
Default Making aluminum heat sheild/air box for intake
I want to make a cold air box for my short ram w/velocity stack...I am going to use aluminum w/ insulation on the inside of the box..I did a search but the info was not ITR related
Has any one with an ITR done this???Does the peskey ABS get in the way???Will it work with the positioning of the intake and filter, since it sits closer to the motor due to the ABS???
Any advice or tips before i start???I would definatly appriciate pics if you have them..
Thanks
Old Sep 6, 2004 | 10:41 PM
DutchITR1689's Avatar
Default Re: Making aluminum heat sheild/air box for intake (NiceDc2r)
I saw this once:
This is mine:
Old Sep 6, 2004 | 10:46 PM
NiceDc2r's Avatar
Default Re: Making aluminum heat sheild/air box for intake (DutchITR1689)
looks nice...Did you just bend the aluminum???
Old Sep 7, 2004 | 02:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiceDc2r &raquo;</TD></TR><TR><TD CLASS="quote">looks nice...Did you just bend the aluminum???</TD></TR></TABLE>
Yes, and bend a lip underneath with a hole for the bolt....
Old Sep 7, 2004 | 07:22 AM
Kicker773's Avatar
doesn't that first pic look like a kegger or maybe its just me still hung over
Old Sep 7, 2004 | 09:30 AM
98ITR#0020's Avatar
Just a little something I made after my Cold air broke.
Old Sep 7, 2004 | 07:23 PM
TypeR864's Avatar
Default Re: Making aluminum heat sheild/air box for intake (98ITR#0020)
98IT#0020.....is there any way u can post direction on how u did that b/c that looks awesome and is it cheaper than buying the heatshield from like neuspeed for ex. Hook up us
Old Sep 8, 2004 | 03:53 AM
Slow_Em1's Avatar
Default Re: Making aluminum heat sheild/air box for intake (TypeR864)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR864 &raquo;</TD></TR><TR><TD CLASS="quote">Hook up us </TD></TR></TABLE>????
"Hook us up"...priceless
Old Sep 8, 2004 | 05:38 AM
Tweakmeister's Avatar
Default Re: Making aluminum heat sheild/air box for intake (Slow_Em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 &raquo;</TD></TR><TR><TD CLASS="quote">????
"Hook us up"...priceless </TD></TR></TABLE>
and the funny part is he lives in the US...
Go to Home Depot and get some roofing aluminum...they sell it in a roll. How you bend it is up to you, but a board with a hammer works fine (rest on board and hammer over).
Old Sep 8, 2004 | 08:53 AM
98ITR#0020's Avatar
first I made a template with cardboard, so I wouldnt screw up the only peice of metal I had. Then I cut and bent the metal. The tube around it is just some hose I had laying around that I cut up the middle and periodically zip tied down( also glued) . To hold the sheild on, I riveted a bracket that would line up with stock airbox holes, then bolted it down difficulty rating: -2
Just one of the many DIY I have found myself doing because I got bored. Not because I'm broke
integracura
Oct 23, 2005 07:56 AM
Sifu
Welding / Fabrication
28
Aug 31, 2005 09:18 AM
4dohs4mohoes
65
Apr 13, 2004 04:42 PM
hazman
Apr 29, 2003 06:24 AM
FULLTHROTTLE
Mar 28, 2002 05:24 AM
