noob question about vafc????
Old Sep 6, 2004 | 10:16 PM
bpowa's Avatar
Default noob question about vafc????
do you need to get a fpr when you have a vfac? or do you need both for maximum tune?? does vafc adjust fuel?
I also would like to know what is the difference between vfac 1 and 2.
Old Sep 6, 2004 | 11:40 PM
Eddiebx's Avatar
yes ideally you would get an FPR with it, so you can tune the fuel better. Thing is with the VAFC, they suck at adding fuel, but are good at leaning things out. so basically you want an FPR to add fuel, then lean out with the VAFC and your golden.
the vafc 2 has more features, and has more adjustment points so you can more finely tune your ****. but the vafc 1 is more than adequate enough for a basic motor with bolt ons and what not.
Old Sep 7, 2004 | 08:19 AM
Pacman
Guest
Posts: n/a
Default Re: (Eddiebx)
What he said..
Old Sep 7, 2004 | 07:32 PM
bpowa's Avatar
Default Re: (Pacman)
sounds good.. anyone else think vfac 1 and 2 are different in anyway??
.. so no matter what i need a fpr with it.. still deciding which vfac is good for me.. leaning more towards 1 version 1 cause of the price and is better looking imo.
how much should i expect to pay for a used one?
Old Sep 7, 2004 | 08:11 PM
JaeOne3345's Avatar
Default Re: (bpowa)
For cheaper then the cost of a vafc you could get a ecu socketed and prepared to accept custom eeproms that you can make with uberdata or crome. But you do the math. .
Old Sep 7, 2004 | 09:44 PM
bpowa's Avatar
Default Re: (JaeOne3345)
i got a socketed ecu.. itr all motor program.. but my motor is not itr..
can you enlighten me about underbeta etc.. i no nothing about certain stuff..
how much cheaper will it cost.
Old Oct 26, 2004 | 08:08 PM
DriveSlowHomie's Avatar
Default Re: (bpowa)
bump...i have a socketed ecu also...can this take the place of a vafc? because i know a person who programs the chips
Old Oct 26, 2004 | 08:58 PM
lemongreenhatch's Avatar
Default Re: (cmGSR916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmGSR916 &raquo;</TD></TR><TR><TD CLASS="quote">bump...i have a socketed ecu also...can this take the place of a vafc? because i know a person who programs the chips</TD></TR></TABLE>
most of the time a chip is a guess on ur setup and are not very acurate and most chips u buy are just to set the vtec for a lower rpm which not always improves on power
and usally ment for a higher rev limit or no rev limit at all with a vafc u can get on a dyno and a tunner can tell when to add or remove fuel and set ur vtec at the right point of engagement
Old Oct 26, 2004 | 09:56 PM
1Quikgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">yes ideally you would get an FPR with it, so you can tune the fuel better. Thing is with the VAFC, they suck at adding fuel, but are good at leaning things out. so basically you want an FPR to add fuel, then lean out with the VAFC and your golden.
the vafc 2 has more features, and has more adjustment points so you can more finely tune your ****. but the vafc 1 is more than adequate enough for a basic motor with bolt ons and what not.</TD></TR></TABLE>
Old Oct 26, 2004 | 10:46 PM
ChaseIntegra's Avatar
Default Re: (1Quikgsr)
A chipped ECU is not a replacement for a VAFC. Yes it changes fuel but you need a VAFC and FPR to tune it to be where it NEEDS to be. A chip isn't gonna set your fuel where it needs to be. Also, w/o a VAFC how are you gonna set your VTEC cross-over for maximum power? So yes, you still need a VAFC and FPR to tune it correctly!
Old Oct 26, 2004 | 11:09 PM
DefiantGSR's Avatar
Default Re: (ChaseIntegra)
yes you need both. Richen with FPR. lean out in areas with VAFC. VAFC can't give fuel during WOT b/c the MAP is already MAXED out.
integra15
Mar 21, 2005 12:05 PM
dand39
Jan 29, 2005 08:55 AM
1999all_motoR_teg
13
Jan 12, 2005 09:53 AM
Grimm
Sep 4, 2003 08:39 AM
Mike95lude
Oct 10, 2001 10:53 AM
