Any one know of a good synthetic replacement for the MTF
Old Dec 6, 2001 | 07:24 PM
NighthawkR184's Avatar
Default Any one know of a good synthetic replacement for the MTF
I already bought the honda MTF to change my tranny fluid with, but I was wanting to use maybe a synthetic like redline. I know that the weight on the Honda fluid is closer to a motor oil as a matter of a fact they recomend using 10w-30 I think if you can't get the honda MTF. So with honda saying that I am scarred to run 80 or 90 weight redline. Also I checked with honda about a limited slip additive for the prelude type S. It should have the same diff as the ITR. Honda said that the recomended fluid was just there MTF. I hope that they are right. Some body stop me if there are wrong. I don't trust some of these guys that work for honda.
Old Dec 6, 2001 | 07:27 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Any one know of a good synthetic replacement for the MTF (flamencoR184)
Stick with Honda MTF, no additives...
Old Dec 6, 2001 | 07:31 PM
Hybrid ctr's Avatar
Default Re: Any one know of a good synthetic replacement for the MTF (itr009)
I agree
stick with Honda MTF
Old Dec 6, 2001 | 07:39 PM
tjtruong's Avatar
New User
Default Re: Any one know of a good synthetic replacement for the MTF (Hybrid ctr)
I agree
thats what i use.. So far no problems.. I would use what Honda Recommends..
tj
Old Dec 6, 2001 | 07:45 PM
Big Teggie's Avatar
Default Re: Any one know of a good synthetic replacement for the MTF (tjtruong)
How about that GM Syncromesh trans fluid. I saw in a few posts some guys recomend it. I was thinking of trying it out my next trans fluid change.
Old Dec 6, 2001 | 08:06 PM
N1Spec's Avatar
New User
Default Re: Any one know of a good synthetic replacement for the MTF (Big Teggie)
ELF Sythentic Tran FLuid
Old Dec 6, 2001 | 08:10 PM
Splat's Avatar
Ain't broke, don't fix it
N1 Spec - Not even sure if we can get ELF fluids here
Old Dec 6, 2001 | 08:11 PM
sackdz's Avatar
It alleviated grinding on my friends sol, and I put it in my ITR, but no help there. Next change I'll go back to Honda MTF I think, but you might want to try the synchromesh.......
Old Dec 6, 2001 | 08:13 PM
Kengs's Avatar
Default Re: Any one know of a good synthetic replacement for the MTF (sackdz)
I've been told that HKS FF/Diff is really good; will try it soon
Old Dec 7, 2001 | 03:35 PM
kkim's Avatar
I asked the same question here a few weeks ago and everyone sort of said to stick with Honda MTF. I want to use redline in the diff because of the success I've had using it in my past cars. I posed the question to the tech guys at Redline and they recommended using the MTL fluid instead of the their gear oil. I'll use the MTL during my next trans fluid replacement. BTW, Honda recommends using MTF (or motor oil) in the trans, like any other Honda trans, so I'm assuming there are no special needs for the LSD in the R.
Old Dec 7, 2001 | 04:28 PM
JohnnyBoy's Avatar
Default Re: Any one know of a good synthetic replacement for the MTF (kkim)
I still like the Redline MTL
kunsky
Aug 3, 2018 07:26 AM
sharpescalade
Jun 2, 2007 07:37 AM
cdansl
Jul 2, 2005 05:30 PM
RAS Motorsports
Oct 10, 2004 12:11 PM
playAho
Apr 2, 2003 07:28 PM
