motor mounts???
i am looking to buy a swap from hmotorsonline...and i hav the option to upgrade the motor mounts to hasport high HP mounts for an extra 300 dollars.. do you guys think i should do it.. thanks in advance
If you don't mind the extra stiffness. It might be a little harsh for daily driving, but it'll help with traction problems. 300 is a bit much, but I don't think you'll find a better deal.
An alternative would be to use stock mounts with urethane inserts, that would be an improvement, but not as rough as solid mounts. Just my $.02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 »</TD></TR><TR><TD CLASS="quote">If you don't mind the extra stiffness. It might be a little harsh for daily driving, but it'll help with traction problems. 300 is a bit much, but I don't think you'll find a better deal.
An alternative would be to use stock mounts with urethane inserts, that would be an improvement, but not as rough as solid mounts. Just my $.02</TD></TR></TABLE>
how harsh are you talking about for daily driven??
D16SohcVtec
Aug 12, 2008 08:03 AM
Cherry Blossom
Dec 4, 2004 04:42 PM
h-spec_crx
Apr 30, 2003 01:03 PM
