type r cames in b16a2
Old Sep 6, 2004 | 05:59 PM
Jeremy-Ryan's Avatar
Default type r cames in b16a2
are type r cams compatible with a b16a2? Is it strictly a bolt on affair?
Old Sep 6, 2004 | 06:33 PM
Forrest Gump 9's Avatar
Default Re: type r cames in b16a2 (Jeremy-Ryan)
It should be!!
Old Sep 6, 2004 | 06:53 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeremy-Ryan &raquo;</TD></TR><TR><TD CLASS="quote">are type r cams compatible with a b16a2? Is it strictly a bolt on affair?</TD></TR></TABLE>
Well, considering the R engine uses the PR3 (b16) head casting, I would sure hope they were "compatible". Although I would not consider cams to be a "bolt on affair".
Old Sep 6, 2004 | 07:30 PM
Drag_Racer_DRU's Avatar
perfectly compatible! just throw them in, a quick valve adjustment and your set...
Old Sep 6, 2004 | 08:00 PM
Default Re: type r cames in b16a2 (Drag_Racer_DRU)
Thanks for the info
Old Sep 6, 2004 | 09:14 PM
LSVTEC 91 Civic's Avatar
Banned
Upgrade the valvetrain while you're at it.
Old Sep 6, 2004 | 10:08 PM
92RED Hatch's Avatar
Default Re: type r cames in b16a2 (LSVTEC 91 Civic)
yeah what they said....also just for future reference all b-series vtec cams are interchangeable to all the other vtec motors
Old Sep 7, 2004 | 01:03 AM
OLM-02R's Avatar
yeah itr cams would be bolt on...might as well change to itr springs/retainer...
Old Sep 7, 2004 | 01:16 AM
Stein's Avatar
Default Re: type r cames in b16a2 (92RED Hatch)
If you don't upgrade your valvetrain dont rev over the stock fuel cutoff.
Old Sep 7, 2004 | 05:39 AM
Big Ern's Avatar
Works mint
Old Sep 7, 2004 | 06:03 AM
Hybrid96EK's Avatar
Default Re: (OLM-02R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OLM-02R &raquo;</TD></TR><TR><TD CLASS="quote">yeah itr cams would be bolt on...might as well change to itr springs/retainer... </TD></TR></TABLE>
There is nothing special about ITR retainers, so why change them?
Old Sep 7, 2004 | 10:34 AM
Pacman
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_Racer_DRU &raquo;</TD></TR><TR><TD CLASS="quote">perfectly compatible! just throw them in, a quick valve adjustment and your set... </TD></TR></TABLE>
DC2teggY
11
Apr 23, 2009 09:49 AM
kenepo_vtec
Jul 4, 2004 10:33 AM
jaydmcrx
May 6, 2003 08:54 PM
KevronsEG
Apr 29, 2003 10:39 PM
