91 crx si crossmember
I need a 'rear' crossmember for a 91 crx si.
which ones work?
I'm thinking a civic one will work, but an integra one won't......
also, I've heard that the hf crossmember is different?
Can someone tell me FOR CERTAIN which crossmembers I can use?
thanks
which ones work?
thanks
Are you talking about the crossmember that the steering rack bolts to (rear front crossmember) or the one spot welded into the chassis at the rear wheels?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">Are you talking about the crossmember that the steering rack bolts to (rear front crossmember) or the one spot welded into the chassis at the rear wheels?</TD></TR></TABLE>
He's talking about the front rear crossmember.
id imagine that the hf cross member is probably not as strong,
i dont know if honda would make 2 diffrent x members but they might.
i would assume that the crx and 88-91 crossmembers are the same.
1991 CIVIC Si uses part number 50200-SH9-A00 crossmember. It fits all 88-91 CRX models (hf, dx, si, auto or manual), and 88-91 CIVIC hatchback and 4 door EXCEPT automatic transmission cars. Hope that helps!
Chris_
Mar 20, 2002 07:04 AM
