One more timing belt question
I did a search, but got conflicting information, so I'll ask it again.
Is it nessesary to remove the valve cover before changing a timing belt? The book I have doesn't say it is, but looking at the engine makes it looks like it is.
I have a 1.5 on a 1990 civic.
Thanks,
Mark
Thanks,
Mark
Its gonna be a little difficult to remove the upper timing belt cover with the valve cover still installed. Im sure I could get the job done with the valve cover still on, but thats because its not my first time. If its your first time, it will prove to be that much more difficult. Just go ahead and take the valve cover off, make it easy on yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mark Finley »</TD></TR><TR><TD CLASS="quote">I saw something online about a gasket and grommets, do all of those have to be replaced too if the cover comes off?
It depends on the age of the gasket and grommets. Usually though, if u are careful and clean them up real good, u can resuse them. Again, save yourself the trouble and go buy a valve cover gasket kit. It will contain all the replacement grommets and gaskets u need. The place i go to only charges like 17 bucks for it.
I was afraid of that. I'm planning on doing the all of the belts, the water pump, and the A/C compressor all at the same time. It looks like it's going to be an expensive job, even if I do it myself.
SteveT2008
Jul 17, 2015 08:25 PM
rice h8r
Jul 15, 2011 09:32 PM
Stillo
16
Jan 4, 2009 09:06 PM
