Help wid Car
Old Sep 6, 2004 | 05:39 PM
Odiedogcx's Avatar
AIRBORNE
Default Help wid Car
Yo my friend just bought a 97' DX Hatch,and he needs help with the Speedometer and electrical... The Speedometer isnt working, it'll jump sporadically all the time.I dont know what's wrong wid it, i even replaced the whole gauge cluster.... And then lights kinda fades in and out, they work 'cept it doesnt seem like they are getting enough power... Kinda like when u have a big *** stereo system in ur car, and ur alternator cant handle all the power being drained for the battery.. Do any of u know what the problem is?? and can tell me how to fix?? thanks alot
Old Sep 7, 2004 | 04:27 AM
mugenhatch92's Avatar
no one is going to help you due to the simple fact that you sound like an e-thug
Old Sep 7, 2004 | 04:47 AM
Ricey McRicerton's Avatar
Default Re: (mugenhatch92)
Maybe your battery or alternator is failing? Other than the lights dimming in and out it sounds like your VSS (which is in the top of your transmission and sends the signal to your speedometer) is going out.
Old Sep 7, 2004 | 04:53 AM
wow i kind of flamed, but when i read it, i have the EXACT same problem in my 98
Old Sep 7, 2004 | 05:43 AM
VTECMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenhatch92 &raquo;</TD></TR><TR><TD CLASS="quote">wow i kind of flamed, but when i read it, i have the EXACT same problem in my 98</TD></TR></TABLE>
ha ! owned, if u were mexican i would call you el sucko
maybe your battery/battery connection is bad, i had that problem on my mazda last winter....
Old Sep 7, 2004 | 05:47 AM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: (VTECMaster)
I'm not too sure, would a fuse possibly have something to do with the lights dimming?If not then check the voltage coming out of the battery, then check the alternator
Old Sep 7, 2004 | 05:53 AM
fakemike's Avatar
Default Re: (turtlecx92)
You could check the engine ground.
Sometimes when fuses go bad a little bit of current still goes thru the fuse but not enuff to power it properly.
You could inspect the fuses.
Old Sep 7, 2004 | 08:22 PM
Odiedogcx's Avatar
AIRBORNE
Default Re: Help wid Car (Odiedogcx)
Alrite, i'll check it out.. thanks.. hope it works, hah
kmeng
Oct 13, 2010 09:47 AM
slowestek
Dec 26, 2009 10:36 PM
DaredeVo
Nov 27, 2009 06:59 PM
CHONCH
12
Sep 9, 2004 10:46 PM
