going turbo... which oem pistons to use?
ok i'm taking my type-s pistons out for an oem piston with a lower compresion and willl be using JE rings..something like accord pistons or maybe even stock h23
so basically which oem piston should i use and how will it hold 12psi? never boosted before so i need info in getting away with stock sleeves and oem pistons with 10-12 psi.
Well for one i don't think the JE rings will work with the OEM piston. You need to check the ring thickness of both the OEM and JE to see if they will work. And 10-12 psi you will not see on a stock block. Maybe 10 psi only on race day and tuned.
show me the person whos running 10 lbs on OEM stock block. Why use OEM pistons when you could use some nice quailty forged internals that are made for boost?? Trying to get around the ol FRM re-sleeving action huh ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">show me the person whos running 10 lbs on OEM stock block. </TD></TR></TABLE>
check out Firedrake's setup on the Dynos page and his site @ http://www.solid-technology.com
I think he is running 12 psi stock engine and has been doing so for quite a while. You can do a search for his usermname here and drag up more info
Pirate
Pirate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">
Pirate</TD></TR></TABLE>
theres a couple of people ive seen around here doing 10 psi stock thats why im asking with no prob.
is there any accord pistons that will drop comp ratio to low nines maybe 8's
accord pistons are not 87mm bore...that is your problem.
I'm sorry but swapping in an OEM H piston like an H23 is kinda dumb..the ringlands won't last very long, but hey if you know what you're doing good luck then. H23 is the lowest compression 87mm bore piston available to you. In an H23 VTEC setup it would be >9.8:1 but I don't have the exact numbers, I would estimate 9.3:1 but if you want actuals ask rick solis since he said he was going to figure this all out a month ago (but I haven't seen anything)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">12 psi daily on pump gas? he tune it himself ?
yes i believe he did, but he is a well respected tuner.
most people can't just tune their own setup's to achieve what he has
if it was me and i was boosting on stock internals, i wouldn't boost more
than 8psi and i would still want awesome engine management.
how long would 8psi with h23 pistons last? i know the h23 pistons suck *** but will 8 psi would start to be a problem with in a year. keep in my mind i have a heavy foot
I ran 8psi of boost on my stock block h23a for over 2 years with no problems. And that was untuned with stock injectors and an FMU, lol. A friend of mine is running roughly 6-7psi with hondata on his stock h23 and he hit 250whp.
Honestly, get hondata, do a conservative street tune for 8psi and call it a day. Don't waste your time with swapping pistons. As far as brian is concerned (firedrake), he has spent a lot on fuel upgrades and that car from my knowlege has been tuned, tuned, and tuned time and time again. A simple 2hr dynojet tune is not going to cut it if you want to run 12psi on a stock block while retaining daily driveability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">I
Honestly, get hondata, do a conservative street tune for 8psi and call it a day. Don't waste your time with swapping pistons..</TD></TR></TABLE>
thank you precision for the info, as far as piatons i want to change them,
well i need to i have type-s ones in there now comp is around 11.5
so does anyone have .25 oversized h23 pistons for sale
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">I ran 8psi of boost on my stock block h23a for over 2 years with no problems. And that was untuned with stock injectors and an FMU, lol. A friend of mine is running roughly 6-7psi with hondata on his stock h23 and he hit 250whp.
Honestly, get hondata, do a conservative street tune for 8psi and call it a day. Don't waste your time with swapping pistons. As far as brian is concerned (firedrake), he has spent a lot on fuel upgrades and that car from my knowlege has been tuned, tuned, and tuned time and time again. A simple 2hr dynojet tune is not going to cut it if you want to run 12psi on a stock block while retaining daily driveability.</TD></TR></TABLE>
this is what I will be doing while I save up for the engine work(which should take about 4 months)and I will have it tuned by boosted_hybrid(Jeff)
SupaFly_Honda
Oct 25, 2003 09:49 AM
Boostless97Lude
Apr 28, 2003 04:30 PM
