Wiring diagram for turbo timer
in general, most turbo timers have five wires to worry about.
red, green, blue, black, grey
red - constant, connect to the big solid white wire
green, usually ignition, connect to the black w/ yellow
blue, usually accessory, connect to the solid yellow wire
black, ground, connect to ground
grey, usually parking brake circuit, run to ebrake wire and T into it
If you find that your engine turns off after wiring it up this way, swap your blue & green wires around. Make sure the parking brake is engaged (the brake light must be on).
EFLander
May 26, 2010 03:50 PM
Spaceballsthelunchbox
Welding / Fabrication
Jun 21, 2005 06:04 AM
(your icon)
