obd0-obd1 conversion help!
Old Sep 6, 2004 | 08:28 AM
illestrolla247's Avatar
Default obd0-obd1 conversion help!
i just recieved my conversion harness from evoulutions motorsports
i have a chipped p28 ecu
i hook all the extra wires up the conversion harness and my car wont start
im wondering if this could be somthing wrong with the distributor or somthing
my setup is a d16y8 motor in an EF but its running obd0 so i already have the obd2 distributor hooked up
would i still need to repin the distributor
anyone have any other ideas please help me out im going to get tuned next weekend and need my uberdata in thanks!
Old Sep 6, 2004 | 09:09 AM
mmuller's Avatar
Mad Scientist
Default Re: obd0-obd1 conversion help! (illestrolla247)
you need an obd1 dizzy
Old Sep 6, 2004 | 10:10 AM
kur0ryu's Avatar
Default Re: obd0-obd1 conversion help! (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you need an obd1 dizzy</TD></TR></TABLE>
what he said plus you need a 4 wire O2 sensor if you haven't done that already. An OBD2 dizzy is missing the crank sensor, which would be located where the oil pump would be on an OBD2 motor. OBD0 and 1 have it in the distributor.
Old Sep 6, 2004 | 01:39 PM
Fobtions's Avatar
Default Re: obd0-obd1 conversion help! (kur0ryu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kur0ryu &raquo;</TD></TR><TR><TD CLASS="quote">
what he said plus you need a 4 wire O2 sensor if you haven't done that already. An OBD2 dizzy is missing the crank sensor, which would be located where the oil pump would be on an OBD2 motor. OBD0 and 1 have it in the distributor. </TD></TR></TABLE>
good way to mis inform someone.lol
for one the car will start with no 02 sensor, and he has a chipped p28 which probably doesnt look for a 02.
second of all the obd0/1/2 distributors do have the cyp " cylinder postion sensor" you are talking about the ckf "crank fluctuation sensor" which is disregarded in his situation. but regardless you need either a obd1 or 2 distributor
and about the starting try swappin the white wires on the distributor
Old Sep 6, 2004 | 05:52 PM
mmuller's Avatar
Mad Scientist
Default Re: obd0-obd1 conversion help! (Fobtions)
mmmm.... obd1 and obd0 distributors are not compatible, you cant just repin it....
Old Sep 7, 2004 | 05:56 AM
Blown90hatcH's Avatar
No he doesn't. Since he has the same motor and distributor, all he needs to do is repin the distributor plug.
Why don't you try calling the company you bought the harness from and get some technical support. Atleast that is what I pride my harnesses on.
Jason
Old Sep 7, 2004 | 07:12 AM
mmuller's Avatar
Mad Scientist
Default Re: obd0-obd1 conversion help! (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
Jason</TD></TR></TABLE>
so, what about the CKP sensor? since obd 0 and obd1 read different pulses and are NOT compatible? one reads double the pulses (cant remember exactly)
I have tried it and the car run like ****
Old Sep 7, 2004 | 09:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">so, what about the CKP sensor? since obd 0 and obd1 read different pulses and are NOT compatible? one reads double the pulses (cant remember exactly)
I have tried it and the car run like ****</TD></TR></TABLE>
He can not run the OBD0 distributor on an OBD1/2 ecu. If he has the crank position sensor in at the pump, and the distributor to match.....which it sounds like it to me.....then he can run that distributor.
Old Sep 7, 2004 | 09:25 AM
mmuller's Avatar
Mad Scientist
oh chit for some reason i thought that he had a obd0 dizzy
Old Sep 7, 2004 | 12:48 PM
i hooked everything up again and it did not start
im getting plenty of spark so that leads me to belive the dizzy is fine
i have the full y8 motor with the y8 dizzy
i knwo the ecu is not bad because i put it in my friends car and it fired up but ran like hell becasue of the programing of the chip
im not too sure what else to check and how to check for it
any suggestions?
Old Sep 7, 2004 | 04:14 PM
might i also mention im running a pw0 ecu as of this moment
car runs fine
i dont understand how the previous owner got an obd2 motor run pretty much flawlessly on an obd0 b16 computer
Old Sep 8, 2004 | 04:13 PM
also are obd1 and 2 dizzys compatible with eachother
and if not would there be a chance i would still get spark even from the obd2 dizzy
Old Sep 8, 2004 | 06:05 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illestrolla247 &raquo;</TD></TR><TR><TD CLASS="quote">also are obd1 and 2 dizzys compatible with eachother
yes they are
Paul26
24
Oct 14, 2012 01:29 PM
Max500
Aug 5, 2010 05:26 PM
Nisif
Aug 27, 2008 02:30 PM
Quick 200k Mile Motor
13
Jul 25, 2002 09:11 AM
