torque help
Old Sep 6, 2004 | 05:47 AM
HOLDEM1981's Avatar
Default torque help
hey guys,
I need to know the torque specs for stock h22 rods, main, and head bolts. I'm reasembling the bottom end of a stock h22.
Old Sep 6, 2004 | 06:38 AM
Shakes's Avatar
space cadet
Default Re: torque help (HOLDEM1981)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOLDEM1981 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys,
helm manual page 7-25
install the rod caps and bearings, and torque the nuts to 34 lb ft.
helm manual page 6-43
tighten cylinder head bolts sequentially in three steps.
29 lb ft
51 lb ft
72.3 lb ft
helm manual page 7-26
check rod bearing clearance with plastigauge then torque the capnuts to 34 lb ft
install main bearing caps and bearing cup bridge.
check clearance with plastigaug, then tighten bearing cap bolts in two steps. int eh first step tighten all bolts in sequence to 22 lb ft. in the final step tighten them in the same sequence to 54 lb ft.
Hope thats what you needed.
to rebuilding without a helm manual
Old Sep 6, 2004 | 08:35 AM
HOLDEM1981's Avatar
Default Re: torque help (Shakes)
Thanks man.
I bought this motor for the crank, my engine is sleeved with new rods pistons, etc. I only needed to assemble this motor with the old crank because a friend wants to put it in a del sol. Thanks for your help.
uberEFtuner
Feb 1, 2015 10:39 AM
H22Luda720
Apr 4, 2006 08:05 PM
eortizr
Aug 23, 2005 10:08 PM
piggypen
Jul 4, 2005 05:07 PM
IH82LOSE
Nov 4, 2003 07:53 PM
