Drive master cylinder brace on an EK ~~ pic ~~
Old Sep 5, 2004 | 11:37 PM
Draggin99Si's Avatar
Default Drive master cylinder brace on an EK ~~ pic ~~
Has anyone installed a Drive master cylinder brace on an EK yet? I heard that 1 hole must be drilled in order to install it onto a 96-00 Civic, is this true? Can anyone confirm this?
Post pics if you have one installed.
Old Sep 8, 2004 | 08:44 AM
Default Re: Drive master cylinder brace on an EK ~~ pic ~~ (Draggin99Si)
Even if one hole needs to be drilled, it still wouldn't be threaded to screw a bolt in.
A search yielded no info on an EK install, so evening bump!!
Old Sep 8, 2004 | 09:04 AM
redlinetuning's Avatar
If i remmber correctly, the location where that hole that needs to be drilled should be enough thickness where you could tap it to proper thread ..
Old Sep 8, 2004 | 09:21 AM
monicle's Avatar
wtf is this thing supposed to do? just brace the master clutch cylinder? Ive never seemed to have a problem with mine moving on me.
Old Sep 8, 2004 | 09:35 AM
cxSHOE's Avatar
Default Re: Drive master cylinder brace on an EK ~~ pic ~~ (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">wtf is this thing supposed to do? just brace the master clutch cylinder? Ive never seemed to have a problem with mine moving on me.</TD></TR></TABLE>
thats because you never had to press down on your brakes hard enough to need it.
Old Sep 8, 2004 | 09:59 AM
Relic1's Avatar
there was some serious debate a while back on those.
The side that swayed me to stay away from them was that the brake pedal brace can/will actually change the suspension settings with it if you push really hard on the brake going into a corner.
Old Sep 8, 2004 | 10:32 AM
RotiEatter's Avatar
Ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">wtf is this thing supposed to do? just brace the master clutch cylinder? </TD></TR></TABLE>
Yes, that sure does sound like what a master cylinder brace might do.
But under intense braking/racing conditions the master cylinder moves around. If you know how to bleed your own brakes watch the MC next time someone is pumping the brake pedel. You'll understand then.
Old Sep 8, 2004 | 10:40 AM
Gump's Avatar
I used to have it, and yes, you do have to ( sold it for this reason) drill holes, the kit comes with two bolts and nuts so that you can mount it up
GSR-TRBO-DA
Nov 26, 2007 08:19 AM
KimChiKid
10
Jan 15, 2007 11:22 AM
wrx'n you
Mar 10, 2006 08:18 PM
johnqt3
Dec 22, 2005 07:27 AM
SpoolinEK
May 10, 2004 11:26 AM
