JR supercharged ITR boost limit
Old Sep 5, 2004 | 07:07 PM
sly_itr2001's Avatar
Default JR supercharged ITR boost limit
Need to know if anybody as a similar setup for comparison. I currently have a stock JR supercharger, (5.5 PSI) kit. The blower as a 4.2" pulley on it. My goal is to go up to 11PSI MAX with this supercharger. I purchased and about to install a smaller JR supercharger pulley (3.8" dia.) and a crank CRV pulley to replace the stock ITR crank pulley. By putting these two, will I exceed 11 PSI?. I figure i should be around that figure, but just wanted to confirm my toughts.
Old Sep 5, 2004 | 09:24 PM
98itr0448's Avatar
Default Re: JR supercharged ITR boost limit (sly_itr2001)
I hope you at least have hondata or aem ems and plan on tuning to run over 9 psi. I wouldn't take it over 7psi personally without engine management. If you already have this then your cool, although I'd get the water mist thing Jackson Racing sells to keep from heatsoak, ect.
Old Sep 6, 2004 | 07:53 AM
Yeah, will be puttin in S200B with 440 injectors
Old Sep 6, 2004 | 02:26 PM
ATgrills.com's Avatar
Carl right???
Last year I just had a CRV pulley and that will give you about 8-9PSI then you figure the smaller blower pulley will put you up to 11-12PSI....
There no way you can run 8-9PSI without a new fuel set up... you have to put ur FMU in the garbage and get yourself hondata if you wanna make any serious SAFE power...
Even with fuel the JRSC is not efficent over 10PSI simply because of too much heat.. so you going to need a water cooler set up like mine or LHT or just the JR water sprayer...
either route you go theres power to be made...
let me know if you have any more questions!
Tyler
Old Sep 6, 2004 | 03:16 PM
Default Re: JR supercharged ITR boost limit (ATgrills.com)
Thanks Tiller, I will like I mentionned earlier put in a HONDATA S200B with RC 440 and a 255LPH Walbro fuel pump. I know that beyond 11 PSI unit overheats, that's why I'm not going over that limit. I'LL probably go with custom intercooling. I've read alot about the water mist, Expensive and not that usefull as per lot of people. I remember reading an article that mentionned that water mist should really be used for very HIGH HP setup, like V8 outputing 500-600 hp. Are you using this water mist or custom intercooling?. I also hear that by intercooling, you actually loose some boost pressure is that true?
Old Sep 7, 2004 | 04:39 AM
go on MR in the "post you vehicule section" ull see the complete built up of my car and motor set up too...
PM me there if u have any questions!
Old Sep 7, 2004 | 08:04 AM
Sorry tyler I'm a newbye, what's MR
Old Sep 7, 2004 | 10:35 AM
silver comet's Avatar
Default Re: JR supercharged ITR boost limit (98Itr-0448)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98Itr-0448 &raquo;</TD></TR><TR><TD CLASS="quote">I hope you at least have hondata or aem ems and plan on tuning to run over 9 psi. I wouldn't take it over 7psi personally without engine management. If you already have this then your cool, although I'd get the water mist thing Jackson Racing sells to keep from heatsoak, ect.</TD></TR></TABLE>
I heard anything over 7psi can be trouble
Old Sep 7, 2004 | 10:39 AM
Default Re: JR supercharged ITR boost limit (silver comet)
montrealracing.com!!
over 7PSI ok buddy start reading!!!
ITR 05082
Engine Management and Tuning
Oct 7, 2010 04:41 PM
gosu08
Apr 27, 2009 07:49 AM
charlessoell
Feb 21, 2005 06:31 PM
suprchrg95
May 17, 2004 01:10 PM
fredtoast
Dec 3, 2002 11:16 AM
