Help HElp Integra pulls to the right when braking
Old Sep 5, 2004 | 01:55 PM
jca0306's Avatar
Default Help HElp Integra pulls to the right when braking
I just got a 93 Integra GS and am having a minor or major problem. When I step on the brakes the car pulls to the right. Even a slight press on the brakes make sthe steering wheel go to the right. I took it to the shop and the quotes me $600. They said my axels had gone bad, and the need to replace various other parts. Should I fork out the $600 to get my baby on the road, or is this something simple that I can take care of. Any help would be greatly appreciated
Old Sep 5, 2004 | 02:05 PM
Raypac's Avatar
Default Re: Help HElp Integra pulls to the right when braking (jca0306)
It's not exactly simple, but its not that hard either. Did you have them check your break lines too? When my car pulled to the right, when I hit my breaks, a place told me I needed to replace my break lines.
Check around...see what other places say too.
Old Sep 5, 2004 | 02:39 PM
POWERINTEGRA's Avatar
Default Re: Help HElp Integra pulls to the right when braking (Sting)
Yeah sounds like an axle problem, how's the aligment, balancing and rotation on the car? All this has to do with this problem sometimes when you replace an axle you have to do aligment etc on the car because they pull to the sides when you brake. Check on this let me know what happens!!
Old Sep 5, 2004 | 04:15 PM
SignfcntOthr's Avatar
Default Re: Help HElp Integra pulls to the right when braking (POWERINTEGRA)
BTW: $600 seems ridiculous to replace some axles, what else did the shop say needed replacing? I'll also suggest what everyone else has, check alignment and brake lines.
Geno's Avatar
I doubt its an axle otherwise you would be saying car pulls to the left when accelerating, I bet your cv boot is cracked and has thrown grease all over ure left brake rotor. Just check the left wheel and look for grease, but it could be an axle or both. A new cv boot will run ya about $20~30 at autozone.
Old Sep 5, 2004 | 04:21 PM
H22A-AllMotor's Avatar
Default Re: Help HElp Integra pulls to the right when braking (Geno)
I've had this problem many many times, get your car aligned, then see how it turns out.
Old Sep 6, 2004 | 08:44 AM
jca0306's Avatar
Default Re: Help HElp Integra pulls to the right when braking (H22A-AllMotor)
thanks guys, I going to try and get alingment if that doesn't work. I'm off to the junkyards. When I asked the shop to give me a brakedown of the $600 they quote they gave me the run around. SKREW THEM!
Old Sep 6, 2004 | 10:20 AM
jojoforhelp's Avatar
Yeah, sounds like that shop wants some of your money....
Sounds like an alignment probem. When was the last time you did any brake work?
therealslickric
Oct 12, 2010 06:26 PM
97CivicExNoob
Jan 18, 2009 10:20 AM
^LORTA^RACING
Jul 24, 2008 03:37 PM
integradb8
Feb 3, 2006 12:24 PM
thatpreludeguy
Aug 25, 2001 08:57 AM
