snap the bolt to hold down ignition rotor.. now what?
Old Sep 5, 2004 | 01:45 PM
TrueUntilDeath.com's Avatar
Default snap the bolt to hold down ignition rotor.. now what?
i was driving and the rotor broke blah blah blah, i replaced it and i over tightend the bolt that holds the rotor but the stud was sticking out a lil and it held the rotor in place so i drove the car home safely..
how do i take out that stud and replace the bolt? tia
Old Sep 5, 2004 | 03:07 PM
importdude2000's Avatar
huh what part are you talking about?
the one screw that holds the rotor in place?
Old Sep 5, 2004 | 11:14 PM
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">huh what part are you talking about?
the one screw that holds the rotor in place?</TD></TR></TABLE>
yeah.
Old Sep 6, 2004 | 08:03 AM
Default Re: (GMR MM 012)
Old Sep 6, 2004 | 08:11 AM
rgbpmp's Avatar
Default Re: snap the bolt to hold down ignition rotor.. now what? (GMR MM 012)
You can maybe cut a slot at the end and with a dremel. Then try to take it off with a screw driver, most likely you cant cause it already snapped. Other than that you might have to tear apart the rotor so that you have more of the bolt exposed. Then try to get it off with vice grips.
Old Sep 6, 2004 | 08:23 AM
Default Re: snap the bolt to hold down ignition rotor.. now what? (rgbpmp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgbpmp &raquo;</TD></TR><TR><TD CLASS="quote">You can maybe cut a slot at the end and with a dremel. Then try to take it off with a screw driver, most likely you cant cause it already snapped. Other than that you might have to tear apart the rotor so that you have more of the bolt exposed. Then try to get it off with vice grips.</TD></TR></TABLE>
where can i get a replacement bolt? is it safe to drive it as is right now?
Old Sep 6, 2004 | 08:37 AM
rgbpmp's Avatar
Part number 30135-P73-004 from your local dealer.
Well if you can tug on your rotor and it doesnt come off then it might be alright. You better get that bold asap.
Old Sep 6, 2004 | 11:22 AM
Old Sep 6, 2004 | 11:31 AM
Old Sep 6, 2004 | 02:03 PM
len's Avatar
len
I would cut a slot in it with a dremel and hope and pray it comes out that way. If that doesn't work, you'll have to drill it out.
Old Sep 6, 2004 | 02:18 PM
Lord Helmet's Avatar
screw extractor is what you need to remove that bolt. pretty easy job to do. I've done it before. http://www.sears.com sells a nice set
Old Sep 6, 2004 | 05:22 PM
Default Re: snap the bolt to hold down ignition rotor.. now what? (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">screw extractor is what you need to remove that bolt. pretty easy job to do. I've done it before. http://www.sears.com sells a nice set </TD></TR></TABLE>
thanks luckily my friend had some and we fixed it, thanks nick
Birdley42008
Oct 1, 2007 03:35 PM
krazyhmongboi
14
Nov 14, 2006 12:33 AM
B18EG6
Nov 3, 2006 03:01 PM
M@
Nov 8, 2005 03:09 PM
BITeR
Jan 7, 2003 10:50 AM
