Need an Ign Wiring harness diag for a DA
I have an JTI autostart alarm on the vehicle and will be adding in a Greddy Turbo Timer. I never had a diagram when installing the alarm and because of that, it does not function correctly. I have no use of the ACC position on my car. Its either On or Off. Anyways, if anyone has a Diag for the Ign. wiring harness on a "92DA, please post it.
well i think all the ignition wiring diagrams are the same for most honda's
heres a site on how to do the turbo timer install
http://www.civicland.com/diy/5...shtml
this diagram worked on my 97 integra. to make things easier, i wouldnt solder the conections right on the igntion switch like how they did it on that website. just splice into the wire further down from the ignition switch and tap into it from there. the solder that is on the ignition switch needs alot of heat to melt it so that u can solder the wires from the turbo timer onto it. i couldnt get the solder to melt using my soldering iron, so i just spliced into the three wires furhter down the igntion switch.
the parking break wire for the turbo timer is easy to find. just remove the console where the e-brake is and u will see a single wire running from it. i think it's green in color. just tap into that wire.
